Author Topic: Bracket/Holder for Backup Light Electrical Connectors - Manual Trans  (Read 3187 times)
Leester
  • USA, VA, Lorton
Hello all, I have installed the backup light plug and harness to the manual transmission and I have connected the male and female 2 wire connectors together. But they just dangle. There must be a bracket or holder that holds the wiring connectors under the car. Can someone let me know what the bracket looks like, where it is located and how it is attached - probably to the chassis?  A photo if anyone has it would be great. Many thanks in advance.
Lee
Lee Backus
1963 220SE Cabriolet
Leester
  • USA, VA, Lorton
Re: Bracket/Holder for Backup Light Electrical Connectors - Manual Trans
« Reply #1 on: February 28, 2021, 16:54:56 »
With a little digging I found this photo. The wiring I am looking at is in the upper right hand corner and it appears that there is a bracket that holds the two connectors. The bracket seems to look like it has three "fingers" that hold the wiring and connectors. I can't find any bracket that looks similar to this in any of the regular resources. At least now I know where its fastened to the chassis, just need to ID the part. Again, thanks in advance.
Lee Backus
Leester
  • USA, VA, Lorton
Finally figured it out, photo 1638 is the bracket and 1641 shows the bracket with the electrical connectors. I have the bracket I need (found it among other parts) but never did find a part number for it.
Hope it helps someone else out.
Lee Backus
