Author Topic: Suggestions for 3d printed parts  (Read 21942 times)
MikeSimon
  • USA, OH, North Royalton
Re: Suggestions for 3d printed parts
« Reply #25 on: June 24, 2021, 13:56:27 »
Are rubber parts easy to 3D print?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #26 on: June 24, 2021, 14:28:57 »
There are two basic rubber chemistries - Thermoset and thermoplastic. Thermoset is a one time non reversible chemical reaction. Thermoplastic is reversible and is processed by heating and cooling the material.
The 3D printing process works using thermoplastic materials. So because of that, you are limited in which materials are available with properties to match. The tradition rubber parts used on our cars are made using the thermoset process. All this to say that if you printed a “rubber” part, it will not feel exactly the same as OEM. May work and look the same, but not exactly the same.
I would talk to a 3D printer and see what material is available. You need to know the application and what the part is going to be exposed to - temperature, fluids, etc.. Also need to know the hardness as measured by Shore A.
MikeSimon
« Reply #27 on: June 24, 2021, 18:06:34 »
I was thinking about the pads on the foot pedals (for another classic car.)
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
dirkbalter
  • USA, CA, Corona
« Reply #28 on: June 24, 2021, 18:22:59 »
Just printed new heater flaps in ABS.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #29 on: June 25, 2021, 01:51:02 »
I am sure they have something close. You would want something soft like a 50 to 60 shore-A material for the pedal pads and your only issue is ozone and UV. Just call a printer and see what they have.
Bill Sgro
  • USA, FL, Bradenton
« Reply #30 on: July 21, 2021, 04:20:44 »
I think a valuable item to be 3-D printed would be the long plastic piece on the under dash unit of a Frigiking AC unit.  Everything else is pretty much indestructible and that piece is very brittle.  Mine is broken and I would like one.  I don't have a file though.
1970 300SEL 3.5
« Reply #31 on: August 01, 2021, 13:31:43 »
I would require a bit of computer wizardry but if someone scanned a nice set of dash parts, dropped the surface 3/16” for padding and covering then printed a foundation for the dash?  This would actually be huge in the Porsche 911 circles where the dashes evaporate leaving you with an expensive restoration or a very expensive replacement.
« Reply #32 on: August 08, 2021, 15:52:01 »
Just came across these guys… currently not got much for a 113 but maybe that’s because no-one has asked them
https://octoclassic.com/about-us
« Reply #33 on: August 08, 2021, 17:05:18 »
That looks like a very interesting site James.
« Reply #34 on: August 09, 2021, 16:04:02 »
Yes, quite a service. You can request a part, and they give the procedure on what you need to do.
Most interesting is the different types of material they offer.
johnk
  • USA, OH, Avon
« Reply #35 on: January 03, 2022, 23:38:24 »
What about printing the yellow clips for the side aluminum trim? They run about $7 each if you can find them.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #36 on: January 07, 2022, 17:54:46 »
Quote
John,
Are you referring to these ones here? ???
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/72-door/72-a-door/clip-dec-strip-plastic-p-6146
johnk
  • USA, OH, Avon
« Reply #37 on: January 07, 2022, 22:42:32 »
Yup,
Wish they were that cheap here. I ended up ordering a complete kit from K&K Manufacturing to get  a decent per piece price but they are all yelllow rather than half yellow and half blue.
Thanks Achim
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
