Author Topic: Steering wheel pad rubber mounts  (Read 1572 times)
heinsbush
« on: March 02, 2021, 21:45:18 »
Hi Friends,
Quick question. I bought the steering wheel and the middle pad separately and now need these little rubber parts to mount it together.
Can you tell me from the pictures which version I need? The earlier ones or the later ones?
Thanks!
Heinz
Re: Steering wheel pad rubber mounts
« Reply #1 on: March 02, 2021, 22:53:54 »
You have the early type steering wheel with horn ring levers protruding the arms of the steering wheel. You need the earlier plastic plug, PN A 111 464 00 24, 3 pcs. They are available at Mercedes, but are expensive, $50 a piece. It is the one with two sets of ribs on its ends.
I do not know if the newer version would do the job and fit.
The PN for the newer one is A 115 464 00 35 and they are $7 a piece at Mercedes.
