Author Topic: Oil Level Increases  (Read 3363 times)
nadeem
Oil Level Increases
« on: March 05, 2021, 22:52:27 »
I have a problem with my 280 SL (Model 1970). Engine Oil Level increases with time and it becomes thin as petrol is going in the sump, mixing with oil.
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Re: Oil Level Increases
« Reply #1 on: March 06, 2021, 04:59:43 »
I would look at the injection pump.
It may discharge gasoline into the engine oil.
Second, the engine and piston rings could be worn.
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
nadeem
« Reply #2 on: March 06, 2021, 19:29:05 »
What is the remedy if the injection pump is discharging gasoline into the engine oil?
Peter h
« Reply #3 on: March 06, 2021, 20:02:26 »
You should first have a mechanic test whether you have gasoline in the oil. Then whether it comes from the engine or the injection pump.
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #4 on: March 07, 2021, 03:31:08 »
It is also likely that you have leaking fuel injectors..... Or leaking cold start valve..... I would look into these possibilities first before touching the fuel injection pump.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
Peter h
« Reply #5 on: March 07, 2021, 05:34:05 »
Interesting, but we should get the gasoline into the oil circuit through defective injection nozzles or cold start nozzles.
Nicolas Aristodemou
« Reply #6 on: March 07, 2021, 18:52:15 »
“Interesting, but we should get the gasoline into the oil circuit through defective injection nozzles or cold start nozzles.”
Yes leaking fuel into the cylinders finds it’s way down the piston rings and ends up in the oil sump....
Nicolas Aristodemou
Nicosia - CYPRUS
« Reply #7 on: March 07, 2021, 22:16:05 »
Use the search function and find out how to check for a leaking cold start injector valve.
If that isn't leaking then it's the pump (or the one-way valve in the oil supply line if your car is fitted with that arrangement.
It's not just elevated oil level and thinned oil you have to worry about.
The fuel contaminated oil willl soften oil seals, particularly front ctrank seal, so you'll get oil leaks which can only be rectified by replacing the seal.
You'll also have "bore wash" where the poil that is relied on to form th seal between rings and bores no longer functions resulting in loss of compression, smoking at the exhaust, poor starting and poor performance.
