Author Topic: cold start nozzle  (Read 1674 times)
Classic garage
  • Bulgaria, Khaskovo, Svilengrad
cold start nozzle
« on: March 08, 2021, 16:05:11 »
Dear all,
The restoration of our 230SL continue with engine rebuilt.
would you help me with part number of the part in red line?
This is some filter (inside with steel net) attached to cold start nozzle.
The net is complete clogged and we can not clear it without damage.
I don't now how important is this net/steal filter inside...
Best Regards
Ivan
Mercedes W113 230SL 1965 Color 158 red interior
Mercedes W111 220SE 1963
Mercedes W114 250C 1969
Mercedes W107 450SL 1976
Mercedes W123 280CE 1984
Mercedes C126 560SEC 1986
Mercedes W107 560SL 1988
Mercedes C126 500SEC 1989
Re: cold start nozzle
« Reply #1 on: March 08, 2021, 16:21:44 »
It is a fine metal screen inside the fitting. It keeps the nozzle on the CSV from getting clogged. You can clean the screen/fitting in a heated ultrasonic cleaning tank with plain rubbing alcohol as the cleaning solvent. Afterward blow clear with compressed air.  If you do not have access to this equipment, then soak it in rubbing alcohol and blow clear with compressed air. You will also need to check and/or clean the spray nozzle.
« Reply #3 on: March 09, 2021, 06:05:07 »
Thanks Peter, yes #92 on their diagram, but try cleaning it first and save 76 Euros!
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #4 on: March 09, 2021, 13:39:28 »
I had to do the same last year, albeit on a 280SL, but same deal. Cleaned every part, changed the o-ring, worked like a charm. I had to pull out the nozzle, as there was gunk at the bottom of the main channel that would not wash away, even in the ultrasound cleaner (thanks to Benz Dr., who provided the tip that the nozzle actually pulls out of the CSV).
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
