I have a 1969 280SE Coupe W111, and the TTS has just gone bad.
If I place a jumper wire from the large terminal to ground, all works as it should.
I have tried to source another OE, but the cost is stratospheric.
I understand that I could use a Porsche TTS, but even those are $250.
Could I just run a ground line to the TTS all the time?
Or maybe put a push button in the cabin to manually ground the system only when starting?
Or should I just bite the bullet, and R&R the old unit?
