Author Topic: Injection pump rebuild Europe  (Read 3110 times)
mauro12
  • Italy, Sicily, Messina
« on: March 09, 2021, 22:27:14 »
Hello guys , I’m selecting the best shop in Europe to rebuild my injection pump and I found this website  .
Any reviews about them ? Please let me know
Thank you
https://www.eisenbrandt.eu/
Mauro Pisani
250sl 1967 5speed zf manual
dirkbalter
  • USA, CA, Corona
Re: Injection pump rebuild Europe
« Reply #1 on: March 10, 2021, 00:19:46 »
Hi Mauro,
I just had mine rebuild locally and the pump looks great. Since you are looking for a shop in Europe, I would also contact the German pagoda site.
https://www.pagodentreff.de/diskussionsforum/
These guys tend to have strong opinions about their local rebuilders.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #2 on: March 10, 2021, 03:24:19 »
Eisenbrand specializes in Porsche 911 injection pumps.
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
hansr433
  • Italy, Tuscany, Torrita di Siena
« Reply #3 on: March 10, 2021, 04:38:56 »
Ciao Mauro,  I will be sending my pump to this company for adjustment and any repairs if necessary.  I spoke with the owner and he requested that I also send him my injectors, labelled by cylinder, and the fuel distribution valves.  This alone tells me that he knows what he is doing.
Dr.-Ing. Fritzsche - Oldtimer Technik
Seestraße 4
D-72649 Wolfschlugen
Tel.: +49 (0) 152 2953 8019
info@oldtimer-technik.eu
www.oldtimer-technik.eu
Hans
1963 220SE Cabrio (Exterior: Navy MB 332, Top: Haarz Navy, Interior: 482P Sahara Beige)
1963 BMW R69S
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #4 on: March 10, 2021, 09:32:41 »
Hans,
You will note that the injectors and distribution blocks and pump are supposed to be all matched. The distribution block outlets are stamped A,B and C and when I removed my injectors I noted that they too had been stamped with these letters. In some cases more than once indicating they had been refurbished.
If you send all these components as a complete set then you know that what you get back will be 100% correct.
The interesting aspect for me is what will they do if any of your injectors are unserviceable. I have not found anybody so far who can refurbish these old style injectors although historically it was possible. By refurbish I mean rebuild, not just stick them in an ultrasonic bath and hope they work.
Please keep us updated if you have info on this.
Regards
1963 220se Cabrio
1968 280se Coupe
mauro12
« Reply #5 on: March 10, 2021, 10:33:18 »
I read that eisenbrandt is specialized in classic Mercedes and Porsche injection pumps. I’m trying to find the best solution for me in terms of price , and time of the service .
Mauro Pisani
hansr433
« Reply #6 on: March 10, 2021, 14:22:25 »
Mauro asked what the fuel distributors were and Peter gave a really good explanation of their function and the fact that they are part of a system and need to be matched for optimal performance.  I am attaching a photo I took at the main Munich MB dealership of a nice W111 or W112 (I don't remember).  The arrows point to the distributors, or distribution blocks as Peter referred to them.
Hans
1963 BMW R69S
mauro12
« Reply #7 on: March 11, 2021, 10:32:21 »
Hi , the engine structure of w111 or w112 is quite different that w113.
If I understood well, they should be located under the Injection pump or near the fuel filter
Mauro Pisani
hansr433
« Reply #8 on: March 11, 2021, 13:23:19 »
Mauro, you are correct.  Since you have a 6-piston pump, you do not have have the distribution blocks used by engines with the 2-piston pump.  You still should send your numbered fuel injectors to the pump rebuilder as they are part of the system.
Hans
1963 BMW R69S
dirkbalter
  • USA, CA, Corona
« Reply #9 on: March 11, 2021, 15:26:11 »
The cold start valve should also be part of the rebuilding process.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mauro12
« Reply #10 on: June 23, 2021, 22:13:31 »
Ciao, volevo sapere se avevi fatto revisionare la pompa iniezione li da oldtimer technik in Germania . A settembre manderò anche la mia e volevo sapere se aveva fatto un buon lavoro .grazie a presto .
Mauro
Hi, I wanted to know if you had the injection pump overhauled by oldtimer technik in Germany. In September I will also send mine and I wanted to know if he had done a good job. Thanks to you soon. Mauro[/color]
« Last Edit: June 24, 2021, 07:04:56 by Garry »
Mauro Pisani
