Author Topic: Pistons set for 250sl  (Read 2552 times)
mauro12
  • Italy, Sicily, Messina
« on: March 12, 2021, 08:29:24 »
Hi guys , I was looking around to have an idea about the cost of an engine rebuild and it seems that pistons for 250sl are very difficult to find . I wrote to mbclassic.de and they don’t know if or when pistons for 250sl 82,5 and 83 will be available again . The same thing in sls shop .
What is the source to buy pistons for a reasonable price in Europe ?
Mauro Pisani
250sl 1967 5speed zf manual
Merc_Girl
Re: Pistons set for 250sl
« Reply #1 on: March 12, 2021, 12:26:50 »
Maura
I’ve contacted the SL Shop in UK regarding your request
This is their response :
we have pistons everywhere from our Holland haul of parts.
There are quite a few variations on sizes, US/UK models.
I am sure we could help but would need the specific car and engine details to help
If you are interested, here is Paul’s email address
mailto:paul@theslshop.com
Katie
230SL
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #2 on: March 12, 2021, 13:20:08 »
I can supply both 82,5 and 83mm. I sent you PM
Regards
Sead
1964 230SL
mauro12
« Reply #3 on: March 12, 2021, 22:28:13 »
Thank you guys . What is the best brand of pistons for our car ? I was wondering why mahle has stopped selling the right pistons for 250sl . Because they have in stock the size for the 230 and 280.
Mauro Pisani
Merc_Girl
« Reply #4 on: March 13, 2021, 03:11:05 »
Sorry I can’t help with that one, maybe others can advise, just say your call for help and no one appeared to reply so asked the folks I use. Maybe others would know?
230SL
mauro12
« Reply #5 on: March 14, 2021, 22:13:44 »
Thank you guys . It seems that sometimes the pistons set for our cars disappear and re appear again after a couple of months. What do you think is the best brand for our pagodas ?
Mauro Pisani
MarkCan
  • Canada, Ontario, Mississauga
« Reply #6 on: March 14, 2021, 23:42:57 »
Where about do you see the stock of Mahle 1st repair size?
mauro12
« Reply #7 on: March 15, 2021, 10:12:27 »
https://www.mbclassics.de/crankshaft-Co_6
Here they have all pistons set for 230 and 280sl.
They used to have for 250 too but they Told me that Right now , the supplier has stopped to provide them pistons for 250sl. Maybe in some weeks will be on stock again .
Mauro Pisani
« Reply #8 on: March 15, 2021, 11:35:55 »
Mauro, i have been checking that as I saw your need and dealers have pistons for 250SL, but nominal (82mm). I did not write it because you said you wanted oversized. But I am writing anyway, in case there is some change.
SEB
  • Germany, Berlin, Berlin
« Reply #9 on: March 18, 2021, 11:28:15 »
Gentlemen
what is your opinion about bushing or slaving? I know, that this in not kosher, and many mechanics do not have this know-how,
but my mechanic rebuild my M129 engine in this technology and I do not see any difference in the work of the engine.
What is important for this discussion in such case mostly you do not have to buy the pistons.
 so Maru probably you do not have to purchase new pistons
Sebastian
« Last Edit: March 18, 2021, 11:38:50 by SEB »
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
« Reply #10 on: March 18, 2021, 11:36:42 »
As you may know, this technology is used very commonly here in Poland. There are highly specialized shops who do that (then there are others who do heads, etc.). You do need pistons often anyway. They usually go back to nominal. I just did that for 190SL.
« Reply #11 on: March 18, 2021, 15:31:12 »
Sleeving an engine block is not that unusual. It is common practice especially on diesel engines, which often times come with sleeves from the factory. Original piston size can be retained in this way. However the original pistons are often worn or damaged and need to be re-worked or replaced. Piston ring grooves wear wider and piston squirts wear as do wrist pins and their bores.
