Author Topic: Several questions on the trailing arms  (Read 1880 times)
CJHenderson
  • USA, AR, Benton
« on: March 12, 2021, 13:05:34 »
I'm rebuilding the trailing arms and first question is the washer over the rubber bushing correct or does the edge needs to be pointing outward? Next, is the trailing arm for the driver side?
1950 MG-TD
Re: Several questions on the trailing arms
« Reply #1 on: March 12, 2021, 13:53:45 »
Your question is a little confusing. The trailing arms are different and must be installed on the correct side. They point slightly inward when installed correctly and the "half crescent" metal ridge is also in-board when installed correctly.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: March 12, 2021, 14:39:25 »
Thanks this is then for the left side.
1950 MG-TD
« Reply #3 on: March 12, 2021, 17:37:19 »
It is for the right side. Once you flip it over (installation orientation) the metal "C" is toward the inside.
« Reply #4 on: March 12, 2021, 17:42:56 »
And the bush is installed incorrectly.
CJHenderson
  • USA, AR, Benton
« Reply #5 on: March 12, 2021, 18:09:16 »
Thanks all
1950 MG-TD
