Author Topic: Recommendations for an Injector Tester and a CO Tester  (Read 2514 times)
hansr433
  • Italy, Tuscany, Torrita di Siena
« on: March 17, 2021, 16:46:07 »
I would think that this topic had already been discussed, but not much shows up when I search.
Would love your thoughts and recommendations for a device similar to this:
https://mercedessource.com/store/bosch-mechanical-fuel-injector-mfi-tester-and-cleaning-kit
and a simple CO Tester to help me set up my engine.  Would really prefer EU sources if it can be helped.  Shipping from the US or outside the EU to Italy is insanely costly and time consuming.
Hans
1963 220SE Cabrio (Exterior: Navy MB 332, Top: Haarz Navy, Interior: 482P Sahara Beige)
1963 BMW R69S
Re: Recommendations for an Injector Tester and a CO Tester
« Reply #1 on: March 17, 2021, 17:04:01 »
Use the Search in the string of items starting with "Home" and use Gunson as the search string. Brand specific yes, but there is a fair amount of information there.
« Reply #2 on: March 17, 2021, 17:16:34 »
For injector tester I bought a diesel injector tester and a gauge that would clearly show 14-16 bar (diesel gauge has too large scale for that).
Something like this, just different gauge.
https://oleje-pema.cz/zbozi/tester-vstrikovacu-trysek-diesel-mar-pol-m57686_267080?gclid=Cj0KCQjw0caCBhCIARIsAGAfuMxRdxaUJycEFOrQpd83TObibB30-mAa_N2y5wJROiRb9xT3Mc7AELUaAomHEALw_wcB
dirkbalter
  • USA, CA, Corona
« Reply #3 on: March 17, 2021, 18:11:17 »
Hans,
I bought the the tester from mercedessource. For some reason mine didn't work initially. Ken and his daughter were very helpful and fast with replacement parts to insure everything works as expected. After that, it worked like a charm. IMO, very helpful to rule out faulty or bad injectors when you are troubleshooting.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MarkCan
  • Canada, Ontario, Mississauga
« Reply #4 on: March 19, 2021, 13:02:36 »
What scale did you end up using? I just got my tester out yesterday and that 3000PSI is not what I would like to see there. I’ll check what’s out there now that will better suit the application. I may also pick up a new gauge with a larger face as the numbers are getting smaller as the “gauge ages”. 😀
« Reply #5 on: March 19, 2021, 18:57:33 »
My eyes are good, it is just that my hands are too short...
Enclosed are pictures of my tester. I am very proud of it.
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #6 on: March 19, 2021, 22:01:00 »
Hans,
I bought a tester on Amazon, there are loads of them listed. It was the same as Wallace Wheeler's from the "Indian Tool Company". It also looks the same as Pawel's.
Regards
1963 220se Cabrio
1968 280se Coupe
MarkCan
« Reply #7 on: March 19, 2021, 22:12:51 »
I just ordered the new gauge online. It will be 600psi scale though. That was the only one I could get for tomorrow. Otherwise a long wait. I’m anxious to do some testing this weekend.
« Reply #8 on: March 19, 2021, 23:40:49 »
600psi is better than 300psi - you still are able to read when the injectors release the load and you have fewer chances to make the hand "go to the other side" from where there is no return. Sometimes when you press the lever too quickly, the hand may go beyond the upper end of the scale and further pass 0 - then it does not come back...
« Reply #9 on: March 20, 2021, 04:32:46 »
I can recommend the Gunson CO meter. Have it and it seems to do the job well, at a reasonable price.
hansr433
« Reply #10 on: March 20, 2021, 08:25:10 »
It seems to be no longer available.  I checked on Ebay and Amazon.
Hans
1963 BMW R69S
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #13 on: March 20, 2021, 09:12:35 »
Search eBay with “Gunson Gas Tester”
Or alternatively get this:
Innovate Motorsports (3837) LM-2 (BASIC) Digital Air/Fuel Ratio Wideband Meter incl. Bosch LSU 4.9 , Black https://www.amazon.com/dp/B001S7W836/ref=cm_sw_r_cp_api_glt_fabc_RBD33YMHENTXCN4TQ7R3?_encoding=UTF8&psc=1
Innovate Motorsports 3728 Exhaust Clamp Cast-Stainless https://www.amazon.com/dp/B000CO9MF8/ref=cm_sw_r_cp_api_glt_fabc_EAAQ54839WCCEKFX8CMC?_encoding=UTF8&psc=1
Search for best prices.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
hansr433
« Reply #14 on: March 20, 2021, 14:42:06 »
Thanks everybody.  Lots of good information there, but obviously I need to work on my search techniques.
Hans
1963 BMW R69S
