Author Topic: Door glass window holders on rolling mechanism  (Read 4175 times)
lpeterssen
  • USA, FL, Miami
« on: March 18, 2021, 10:31:35 »
Dear friends
Looking for the parts circled in red on the attached picture that allow to fix door glass windows to the manual rolling mechanism.
Many thanks
L.peterssen
Re: Door glass window holders on rolling mechanism
« Reply #1 on: March 18, 2021, 11:31:41 »
The outside ones I see available at Mercedes
left A 113 720 01 47
right A 113 720 02 47
They are ca EUR 150 each.
But I cannot find the inner ones.... I will keep looking.
You will need the rubbers for them. There is a set at SLS, but those are easy to fabricate yourself.
What you will also need is 8pcs of rubber bushings, available at Mercedes, A 000 987 08 42, about  1EUR each.
« Reply #2 on: March 18, 2021, 15:33:17 »
I believe the ones used on the W107 cars will work fine.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: March 18, 2021, 15:39:35 »
The 8 bushings can be created by slicing the desired thickness from the correct size rubber hose. 66nblue posted a thread on it here.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #4 on: March 18, 2021, 18:37:30 »
If you slice them from the hose, I would make sure to use a hose with as thin wall as possible. Thinner wall: more adjustment space.
lpeterssen
  • USA, FL, Miami
« Reply #5 on: March 19, 2021, 11:38:59 »
Many thanks Pawel
lpeterssen
  • USA, FL, Miami
« Reply #6 on: March 19, 2021, 11:45:02 »
Dear joe
I hope you are right because that will be the cheapest solution to use that part coming from a R107.
 Have been assembling this pagoda for years but as situation in Venezuela is very fragile I did no want to spend so much on it until we become free again and economy flourishes.
« Reply #7 on: March 19, 2021, 11:54:10 »
In SLS the 107 window rails are EUR 130 a piece. You would have to find them second hand I suppose.
