Author Topic: 123 ignition  (Read 1848 times)
David Robinson
  • Ireland, Connaught, Galway
123 ignition
« on: March 18, 2021, 22:13:21 »
Just received my 123 ignition  today. Probably will have requests for help soon.
« Last Edit: March 18, 2021, 22:37:51 by David Robinson »
zak
  • USA, NJ, Bernardsville
Re: 123 ignition
« Reply #1 on: March 18, 2021, 22:29:53 »
Good stuff David. Hope to hear about better performance and reliability.
The pros here will be glad to help you on the install.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
dirkbalter
  • USA, CA, Corona
Re: 123 ignition
« Reply #2 on: March 18, 2021, 22:36:27 »
I have one too. Love it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Paul & Dolly
  • i Car
Re: 123 ignition
« Reply #3 on: March 19, 2021, 10:01:45 »
David
There is good information in the Technical Manual above for the 123 Distributer.
Many of us use them, usually without problem.
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
Re: 123 ignition
« Reply #4 on: March 26, 2021, 07:55:44 »
It is good that you got the programmable 123 unit via Bluetooth.
You can ask your supplier for the appropriate  advance curves (centrifugal advance and vacuum advance maps) that you can use to programme the unit.
If you need help in that maybe I can help
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
