Author Topic: Radio Advice  (Read 8877 times)
TOM250SL
  • USA, IL, Chicago
Radio Advice
« on: March 20, 2021, 14:59:53 »
Hi Everyone.
I'm beginning to ponder interior restoration of my '66 250SL and before I go all in, I figure I should also replace the after-market stereo/cassette that was in the car when I bought it (see attached first photo).  Of note are the cuts in the dash panel, exposed fasteners and NO cigarette lighter.  Based on my data plate radio reference number (515) the original radio would have been a Becker AM/FM USA. A couple of questions I could use help with:
1.  Did all 113's have cigarette lighters? I haven't seen any pics of dashes without them.
2.  See the attached second photo of a Becker USA Radio - I believe this is the correct radio. Can anyone confirm?
Thanks in advance for any comments.
GM
  • USA, CA, San Pedro
Re: Radio Advice
« Reply #1 on: March 20, 2021, 16:05:45 »
First stop might be your build plate in the engine compartment to see if the car came with a radio from the factory (vs dealer installed):
510 Radio Becker Mexico (Olympia with stereo-cassette)
511 Radio Becker Mexico, cassette, full stereo
512 Radio Becker Europa cassette
513 Radio Becker Europa stereo, USA
514 Radio Becker Europa LMKU (LW, AM, SW, FM)
515 Radio Becker AM, FM, USA
516 Radio Becker Grand Prix
517 Radio Becker Monte Carlo
518 Radio Becker Europa stereo
519 Radio Becker Grand Prix, USA
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #2 on: March 20, 2021, 18:19:08 »
1.  Yes.  And you can buy the replacement panel for the one that has been hacked up.
2.  No.  That is absolutely NOT the correct radio.  You would have a Europa TG or a Europa TR with the SMALL FACE.    Read about it here:  https://www.sl113.org/wiki/Electrical/Radio
Scott Allen
'67 250 SL (early)
Altadena, California
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #3 on: March 20, 2021, 18:22:15 »
This is what your radio should look like (if you get a Europa TR). The TR has a separate amplifier not shown in the picture.
Scott Allen
'67 250 SL (early)
TOM250SL
  • USA, IL, Chicago
Re: Radio Advice
« Reply #4 on: March 22, 2021, 00:11:46 »
Thanks for your input.  Scott thanks for sending a pic of the radio.  I have to say though that I'm confused as to why it should be the Europa TR.  My build plate does have the 515 code, which is why I assume it should be the Becker USA.
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #5 on: March 22, 2021, 00:16:11 »
No no no.  The radio pictured is from about 1972.  6 button Europas are wrong.   Plus they are big-chassis, not small chassis and face like you need for your car.   In your year, the only AM/FM Becker options would be the TR or the TG, but most importantly, it must have the small face.  This does not contradict the 515 code - the AM/FM Becker for that year would be a TR or TG.  The radio on Becker USA (which has no connection with the original Becker) is a MUCH later radio.  And it has big knobs.  You need small knobs, small faceplate.  Choices are a Europa TR (AM/FM or 4 band), Europa TG (same choices), Mexico TR, and Grand Prix TR.
Scott Allen
'67 250 SL (early)
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #6 on: March 22, 2021, 00:20:04 »
List corrected for what would be available in 1966.
Scott Allen
'67 250 SL (early)
GM
Re: Radio Advice
« Reply #7 on: March 22, 2021, 01:02:56 »
Becker Radio Model History (per http://www.blackforestllc.com/becker/)
Gary
1971 280SL - Sold
Black MB Tex
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #8 on: March 22, 2021, 01:05:25 »
Unfortunately useless since it doesn't cover the appropriate year.   All I can say is Europa TR, and I'm fairly confident that I am correct.
Scott Allen
'67 250 SL (early)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: Radio Advice
« Reply #9 on: March 22, 2021, 01:36:57 »
..All I can say is Europa TR, and I'm fairly confident that I am correct.
I agree, the 515 AM/FM (USA) option code would be a Europa TR. I have an early 64 230SL with option code 515, which for Mar-Apr 1964 would be a Europa TG. The transition from Europa TGs to TRs took place during 1964.
Re: Radio Advice
« Reply #10 on: March 22, 2021, 01:49:33 »
To be absolutely sure in addition to paint plate code 515 we need to know your VIN. Is it before or after 002980?
TOM250SL
  • USA, IL, Chicago
Re: Radio Advice
« Reply #11 on: March 24, 2021, 14:41:41 »
No, my VIN is after that - 0133xx
Re: Radio Advice
« Reply #12 on: March 24, 2021, 20:06:28 »
I believe we are not on the same page, only 5196 250SLs were made: https://www.sl113.org/wiki/DataCard/USModelYear
If your VIN was before 113 043 002980 then the radio should have the small knobs and it is mounted on a separate cover plate. In that case just follow scoot's recommendation.
For a later VIN the radio should have the larger knobs and it is inserted into a standard DIN cut-out.
TOM250SL
  • USA, IL, Chicago
Re: Radio Advice
« Reply #13 on: March 25, 2021, 00:18:25 »
thank you 66andBlue
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #14 on: March 25, 2021, 00:25:09 »
Just to confuse things a little, here is a picture of the WRONG Europa TR.  Do not get this.  Get the one like in my picture above.  (In reply #3)
« Last Edit: April 09, 2021, 14:38:28 by scoot »
Scott Allen
'67 250 SL (early)
mazmonza
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Re: Radio Advice
« Reply #15 on: April 04, 2021, 07:08:32 »
I have a Europa Courier on my early 250, I now it is not for my car what year is it from?
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
mazmonza
Re: Radio Advice
« Reply #16 on: April 08, 2021, 13:55:09 »
That should read  Europa Kurier, I can't find a reference, any help please. :)
Maurice
2000 Ducati 748s
1970 Ducati Monza
Re: Becker Europa Kurier
« Reply #17 on: April 08, 2021, 15:46:42 »
70ies, surely not for the Pagoda anymore.
About 1974 and later.
Depends on the code and serial number on the label of the radio. To be checked.
Then it can be deciphered when exactly it was made.
(BeckerEuropaStereo&GrandPrixStereoaficionado)
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #18 on: April 08, 2021, 15:51:38 »
Is that the low-end AM only radio?
Scott Allen
'67 250 SL (early)
mazmonza
Re: Radio Advice
« Reply #20 on: April 09, 2021, 07:52:26 »
Thank you for the information, mine is mono with the pinstripe face,
it looks right so i will stick with it.
Does anyone know who in the UK is good to restore these radios.
Maurice
2000 Ducati 748s
1970 Ducati Monza
Re: Radio Advice
« Reply #21 on: April 09, 2021, 08:49:05 »
Chrome of London.
Very good experience with them.
scoot
  • USA, CA, Altadena
Re: Radio Advice
« Reply #22 on: April 09, 2021, 14:37:49 »
Chrome of London.
Yet their website shows a picture of the WRONG Europa TR...  See post #14 above.
Scott Allen
'67 250 SL (early)
Re: Radio Advice
« Reply #23 on: April 09, 2021, 19:15:48 »
I am sure you are right. But for me what matters most is not necessarily originality advise, but rather technical skills and customer service.
