I would go for the programmable bloutooth 123 ignition, since your car being a 1970 model should have the emissions control system. I would program that to ignore vacuum inputs and utilize only the centrifugal advance curve. I have available curves should you decide to go that way. You will have a so much smoother running engine - you will think you are driving a modern car!
