Author Topic: Have the rear end up  (Read 1623 times)
CJHenderson
  • USA, AR, Benton
« on: March 20, 2021, 23:44:37 »
Have the rear end up but am stuck with the trailing arms 36mm bolts. I can get them threaded most of the way then jams up. I know from first hand they were a royal pain disassembling them but it seems to be as bigger pain reassembling them.
1950 MG-TD
Re: Have the rear end up
« Reply #1 on: March 21, 2021, 02:07:05 »
Pretty sure I attached the trailing arms to the rear axle the attached the trailing arms to the floor of the car.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: March 21, 2021, 23:31:36 »
Had to ream the holes on the rear axle so the trailing arm mounting bolts can pass through, now to compress & lock down the coil springs to bolt up the trailing arms then to mount the wheels and back to the body shop for final paint.
1950 MG-TD
