Author Topic: Starting to put the engine back together  (Read 2162 times)
CJHenderson
  • USA, AR, Benton
« on: March 27, 2021, 21:15:34 »
After getting the under carriage bolted down I'm turning to putting the engine back together. Getting ready to install the fuel injector pump. In the pagoda technical manual the engine must be set at 20deg after top dead center. I have to assume that the 20 ATC which is on the same mark as the 60 degree mark, is this correct?
1950 MG-TD
