Author Topic: Post restoration mystery.  (Read 3562 times)
TOMNISTUFF
  • Canada, Qc, Levis
« on: March 28, 2021, 00:24:09 »
Does anyone know what this is?  It’s like fine grain particle board material.
Tom Kizer
TOMNISTUFF
  • Canada, Qc, Levis
Re: Post restoration mystery.
« Reply #1 on: March 28, 2021, 00:27:59 »
I forgot the photo.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #2 on: March 28, 2021, 00:31:10 »
From memory 🤪🤪 it sort of looks like the reinforcement pieces for the left and right dash parts. Used on the both left & right A pillars.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #3 on: March 28, 2021, 01:48:04 »
I don't remember seeing this piece in the 1964 or the 1966 230SL
Could be a shim put underneath the the wood pieces on the window?
The hole distance could fit the studs for the blue nuts.
« Last Edit: March 28, 2021, 02:30:22 by 66andBlue »
mrfatboy
    • Mrfatboy
« Reply #4 on: March 28, 2021, 01:51:02 »
Actually I think Alfred is correct. I was close🤣
Signal Red
4 Speed
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #5 on: March 28, 2021, 03:54:13 »
I agree.  I spent a lot of time working in that area.  I don't remember ever handling that piece.  It could be that it fell out when I was removing the woodwork.  It's one of those "FAIRYSNUCKiT" parts.  The parts fairy snuck it into my parts box when I wasn't looking.  I'll look if I can get in there to see.  It reminds me of a piece screwed to the door frame to stop the rubber sleeved window counter balance spring from rattling, but it's not the right shape or size.  Thanks mrfatboy and Alfred.
Tom Kizer
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #6 on: March 28, 2021, 07:15:32 »
Between two dash panels as stated above.
1964 230SL
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #7 on: March 29, 2021, 00:22:58 »
Hi, Sead,
That is perfect!  Thank you for the confirmation.
Tom Kizer
« Reply #8 on: March 29, 2021, 19:16:45 »
Tom,
keep in mind that these shim pieces are not standard and present in all 230SL.
When I opened the door panel on my 1964 230SL I noticed a small shim piece at the edge of the panel. Never seen that before.
Another but more common piece is the one glued by "96" to the panel in the center to protect it from the screw.
They were probably used as needed by the installer.
« Last Edit: March 29, 2021, 23:26:41 by 66andBlue »
« Reply #9 on: March 29, 2021, 19:47:27 »
Interesting! Some things were somewhat "random"...
« Reply #10 on: March 29, 2021, 23:26:23 »
Considering the high number of weekly changes during the first 9 months of production I would not really call it "random" but "efficient".
Keeping the assembly line moving while trying to adjust two trim parts perfectly required some extra pieces and ingenuity.  ;)
« Reply #11 on: March 30, 2021, 06:47:18 »
Of course, efficient it is. Random was not the best word there indeed!
