Author Topic: viscous fan clutch play  (Read 1867 times)
EdwardBernard
  • Canada, AB, Edmonton
« on: March 30, 2021, 21:23:47 »
On my 230 SL I noted that there is a small degree of "wobble" or play (less than 1 centimetre) when I move my metal fan blades front-to-rear, which makes me suspicious of the fan clutch. My water pump is new. The engine has not been run, so I can't assess the fan clutch's behaviour at idle. I have not yet installed my radiator, so if I need to replace the fan clutch, this is the best time to hear any bad news.
   I also read in some spots that the 230 SL M127 engine didn't have a fan clutch-- true? My set-up is definitely with a fan clutch and five-blade metal fan. Thanks for any insights...
Bill Leddy, Edmonton, AB, Canada
1964 230 SL, red, manual, ps
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
Re: viscous fan clutch play
« Reply #1 on: March 31, 2021, 02:36:04 »
Yes the 230SL is supposed to have a four bladed fan without a viscous coupling. The 250 and 280 SLs have the six bladed fan with a viscous coupling. See attached photos. So having a 5 bladed fan with a viscous coupling on a 230 SL  (M127 engine) is definitely non standard. As for the play that you are experiencing, if the water pump is new and the fan/coupling screws are tight it can be nothing else that a defective viscous coupling.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
« Reply #2 on: March 31, 2021, 04:38:27 »
Perhaps non-standard in the strictest sense of the word but you could request a water pump for a viscous clutch as a SA.
My 1966 230SL came that way.
wayne R
« Reply #3 on: March 31, 2021, 11:59:41 »
Edward,  i know with my years on other brands, mainly GM, a viscous fan clutch at about  70degress temperature,
cold engine, by spinning with your hand,  fan should not spin more than  one and quarter  to one and a half times.
and should not half any play in bearing.
EdwardBernard
« Reply #4 on: March 31, 2021, 16:18:01 »
Thank you both! I appreciate your expertise.
