Author Topic: Removing axle using a slide hammer  (Read 1540 times)
CJHenderson
  • USA, AR, Benton
« on: March 31, 2021, 14:34:18 »
Can both left and right axles be pulled using a slide hammer or do I need to remove the housing that has the rubber boot on it?
1950 MG-TD
Re: Removing axle using a slide hammer
« Reply #1 on: March 31, 2021, 18:54:59 »
You do not need to remove the rubber boot.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: March 31, 2021, 23:27:46 »
Thanks good to hear since I might have to change out the backing plate gasket
1950 MG-TD
