Author Topic: Changing ashtray lid insert  (Read 12704 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
Re: Changing ashtray lid insert
« Reply #25 on: January 10, 2023, 15:16:52 »
Could the color of the ash tray insert be based on whether leather or tex interior?
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
« Reply #26 on: January 10, 2023, 18:59:03 »
Quote
No, John.  :-X
This is not a primary question of leather versus MB-tex but only of the interior color code itself.
As Alfred mentioned earlier, only 230 SLs after 012467 had "colorful" lid inserts, all the ones before had only black.
The specific color of the padded insert was chosen in line with the interior list (Ausstattungs-Liste), which Alfred showed earlier.
The insert was always plastic liner, nothing else.
(former 113 ashtray collector)
« Reply #27 on: January 11, 2023, 01:07:46 »
Can someone help me out....
The ashtray has a lid, a chrome surround and a box. The thread above is about the lid going on the surround.
Am I to understand that the ("chrome") surround and (zinc finish) box are "one" item or are they separable. If so, how? I'm looking to keep the visible parts but change the box underneath...
Hello James,
the "box" is spotwelded to the chrome surround. To get it them apart you can drill out the "spots". When you change the box and want use it again keep in mind to leave the two vertical spring steel strips in place to insert the box snugly into the wood box. Also the lid needs the spring steel tab that Shvegel manufactured.
For one mod I cut the bottom out and added a switch and USB port into the shell but did not separate the chrome surround from the box.
« Last Edit: January 11, 2023, 01:19:05 by 66andBlue »
« Reply #28 on: January 11, 2023, 07:22:01 »
Thanks Alfred
Exactly what I was after. So if I was to do something similar to your usb sockets, i am looking at putting my cognac lid on a “replacement yet modified” box/surround, or doing surgery on the underside of my complete unit.
« Reply #29 on: November 06, 2024, 16:34:43 »
In answer to my own question... I drilled three small holes in the back face, left side bottom of the ashtray, drilled bigger and dremel-ed out a slot. Through that I fed a USB cable (from the inside). The cable goes down the join in & then under the carpet between handbrake and shifter to a socket that was fitted ages ago on the tunnel. Inside the ashtray are now three charger cables (micro, USB C and lightning) that are hidden when not in use and easy to access and use for charging in the console tray.
WRe
« Reply #30 on: November 06, 2024, 18:04:29 »
Here are all separate parts.
...WRe
« Last Edit: November 10, 2024, 10:03:35 by WRe »
