Author Topic: Transmission shaft and wiring  (Read 1953 times)
CJHenderson
  • USA, AR, Benton
« on: April 10, 2021, 12:41:07 »
While cleaning the transmission I noticed that the input shaft can be wiggled by hand. Is this normal? Also the three wires that is on the transmission is in very bad condition. Can I order a new one or just build one?
« Last Edit: April 10, 2021, 12:47:40 by CJHenderson »
1950 MG-TD
cfm65@me.com
  • Cape Town, South Africa
Re: Transmission shaft and wiring
« Reply #1 on: April 10, 2021, 13:42:52 »
Hi CJ,
Yes, the shaft is supposed to be a little loose.I am sure you could easily make up new wires.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
CJHenderson
  • USA, AR, Benton
« Reply #2 on: April 10, 2021, 14:15:15 »
Thanks, that just took a load off of my mind.
1950 MG-TD
cfm65@me.com
« Reply #3 on: April 10, 2021, 20:17:03 »
Yep, I believe they are all the same, from Model T%u2019s to Porsches and Ferrari%u2019s. The idea is not to have an absolute rigid/perfect connection between the engine and transmission. Just a little play is quite common on most cars I have seen.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
