Author Topic: Trunk Lock Piece  (Read 4941 times)
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Trunk Lock Piece
« on: April 13, 2021, 02:11:02 »
I need the L-shaped metal part that attaches to the back of the trunk lock (circled in photo).  This part does not appear to have its own part number, but I thought someone might have a spare one (with or without the screw that holds it in place) lying around somewhere.
               -David
-David Pease
MikeSimon
  • USA, OH, North Royalton
Re: Trunk Lock Piece
« Reply #1 on: April 13, 2021, 13:11:51 »
A piece of metal from the hardware store, a vice, a hacksaw, a drill and a hammer should do nicely!
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #2 on: April 13, 2021, 19:47:16 »
Thanks, Mike.  That is my fallback plan.  However, I wasn't sure if this piece has some kind of alignment "tenon" to fit the slot in the back of the lock, and fabricating that might be a little challenging for someone who's not a metalworker.  Thought I'd try the easy way first.   ;)
           -David
-David Pease
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #3 on: April 13, 2021, 23:41:19 »
As I expected, there are tabs on the back of the piece to keep it aligned with the lock barrel.  As someone with little metalworking skill or equipment, I might have a bit of difficultly with those.
         -David
-David Pease
Desertpagoda
  • USA, AZ, Tucson
« Reply #4 on: May 08, 2021, 01:13:40 »
I had this need also, never found one, but the dealer has the whole assy avail, not too much $$$
kb
« Reply #5 on: May 26, 2021, 21:49:42 »
Hello David,
The W110/W111 fintail sedan should have the same L-shaped piece.
Sometimes its best to buy a very bad old (sedan or SL's) lock. This part usually never deteriorates...
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #6 on: May 27, 2021, 19:57:51 »
Thanks, Achim,
I'll look around for one.
         -David
-David Pease
