Author Topic: Soft top frame fastener question.  (Read 5173 times)
Ollie
  • Canada, Alberta, Red Deer
« on: April 19, 2021, 00:52:11 »
My 1967 Pagoda has a soft top frame "fastener" that keeps falling out unless I keep it in with my finger as I fold it. I am sure there is abetter term for this, but the photo's should explain. The thread on it seems stripped. Any advice on how to fix/remedy this situation? Your advice is much appreciated.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Soft top frame fastener question.
« Reply #1 on: April 19, 2021, 01:34:35 »
These bolts were punched at the ends (see picture) to prevent loosening. If the bolt easily falls out I would guess that someone tampered or damaged it so they could remove it to fix the frame.
Hopefully somebody has an elegant way to fix.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Ollie
« Reply #2 on: April 19, 2021, 01:50:50 »
Thanks mrfatboy, I thought those two little holes were there for a reason!
mrfatboy
    • Mrfatboy
« Reply #3 on: April 19, 2021, 01:54:22 »
Maybe using some red loc-tite would do the trick🤷‍♂️
Signal Red
4 Speed
dakman29
  • USA, WA, Spokane
« Reply #4 on: April 19, 2021, 04:06:43 »
Try a helicoil insert. It will work in the short term. Can’t say for how long.
doitwright
  • USA, IL, Willowbrook
« Reply #5 on: April 19, 2021, 12:47:58 »
I am not sure this will help. If you go to BlackForestLlc.com they have a series of photos where they do this repair with any insert under the Classic Workshop link. However, you need to have Flash on your computer or the photos will not appear. Flash is not longer available or supported by Adobe.
Frank Koronkiewicz
Willowbrook, Illinois
Ollie
« Reply #6 on: April 19, 2021, 16:40:46 »
Thanks for the replies. I have been tempted to do the loc-tite, but I am worried about that option. I have not needed to remove any of those  soft top frame fasteners in 25 years, but watch if I do loc-tite, I will need to!  I'll see if I can find helicoil close to me.
mrfatboy
    • Mrfatboy
« Reply #7 on: April 19, 2021, 17:01:42 »
You could always try Blue Loctite and see how it goes. It’s less permanent.
Signal Red
4 Speed
« Reply #8 on: April 19, 2021, 23:37:07 »
I have a really elegant way to fix that.  Some time ago I purchased a complete kit of the soft top screws because I was going to restore my slightly rusty, slightly broken soft top.  Well it turns out "Slightly rusty"  turned out to be massively tar and Nicotene coated.  I need one screw to repair mine so if you message me your address I can send you a new screw gratis.
Ollie
« Reply #9 on: April 20, 2021, 17:39:14 »
Thank you so much, that is really awesome and extremely kind of you!
Victor113
  • USA, CA, Newport beach
  • 68 250SL
« Reply #10 on: September 09, 2024, 16:23:18 »
Do you by any chance still have an extra 1-2 screws for the soft top frame as I am in need of one missing and one rusted version for replacement? Thank you in advance for your help.
68 250SL aka Mr Big
« Reply #11 on: September 10, 2024, 07:18:07 »
Just be careful when you buy set of screws for soft top and check with the vendor if they have fine threads. I bought a set from SLS some time ago and threads just did not much as there was a fine thread in the frame and screws had the regular one.
dirkbalter
  • USA, CA, Corona
« Reply #12 on: September 11, 2024, 17:43:05 »
Pawel, I bought the set from SLS as well but had no thread issues AFAIR. Not sure if our frames are the same though.
Have you guys seen below. Interesting.
https://www.youtube.com/watch?v=MXqCmubOUkI
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #13 on: September 11, 2024, 19:49:57 »
Authentic classics sells the screw and also an oversized version which means that more than a few have been stripped out.
https://www.authenticclassics.com/230SL-250SL-280SL-Convertible-113-Chassis-s/1.htm?searching=Y&sort=13&cat=1&show=32&page=1&search=%20Soft%20top%20frame
Lori
1968 280SL (US)
« Reply #14 on: September 12, 2024, 12:00:32 »
Indeed could be that they are not. Best to check the threads.
