Author Topic: linkage does not open Fully the trottle ...  (Read 1652 times)
erickmarciano
  • Canada, Quebec, montreal
« on: April 23, 2021, 01:24:24 »
Hi guys got a 280Sl Euro 4 sp.
going over the linkage again and have a few questions ?
I adjusted the injection pump Rod with the hole in the linkage , then the venturi . i adjusted the venturi as per the linkage tour <closed just before it starts binding).
1-I disconnected the linkage going to the Engine block and . If open the linkage full by hand the pump hits the stop but the venturi still has like 3mm before it is full opened .is this normal?
2- I was never able to adjust my gas pedal properly it need a complete reset since the  settings on the firewall  were messed with.the tour does not show in how to do this . I guess we start with the top of Engine linkage then...?
thanks
Erick Marciano
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: linkage does not open Fully the trottle ...
« Reply #1 on: April 23, 2021, 02:34:39 »
Eric,
The linkage tour in the Tech Manual sets out perfectly the steps needed to set up your linkages.
https://www.sl113.org/wiki/Restricted/Linkage-tour
Unfortunately you need to be a Full Member to access this info.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: April 23, 2021, 02:43:11 »
The Venturi lever does stay open just a bit when the FI pump is on its stop. However, that is just the tip of the iceberg. I second what Garry says and joining is a great investment in your car. The linkage tour will show you the MANY in and outs of the system. The linkage design is typical of the many functions on this car. Intricate and complex. Being a member of this group will give you the tools and info to set your car up the way it is supposed to be.
« Reply #3 on: April 23, 2021, 08:42:00 »
As for your question about the gas pedal - you are a Full Member. Gas pedal work is mentioned in the Linkage Tour.
I may add: look carefully along gas pedal shaft and levers so that nothing blocks the movement.
erickmarciano
« Reply #4 on: April 24, 2021, 00:36:53 »
I still don’t find it clear
The engine linkages are all good
Should the vertical link image have to be under tension to connect to the one with the roller ?
Let’s say from the pedal to the engine pivot and vertical linkage is all messed up how do we go about in sertting  it up ?
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #5 on: April 24, 2021, 02:50:51 »
Have in mind that even if you adjust your linkages as per the excellent linkage tour article there will still be a few mm at the end of the throttle travel that cannot be reached, ie throttle would open 95% of its full opening potential. I understand that your car is a euro spec manual so you wouldn’t have the split linkage on your Venturi rod.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
lreppond
  • USA, CA, San Leandro
« Reply #6 on: April 27, 2021, 02:16:27 »
https://youtu.be/GvgXzmgQLP0
Have you also checked out this video?   Combined with the linkage tour may help you.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
