Author Topic: Hazard light location 250SL  (Read 3610 times)
Mohan58
  • Malaysia, Selangor, Petaling Jaya
« on: April 25, 2021, 02:13:15 »
Hi guys,
I just managed to find an original switch for the hazard lights for my 250SL. Could anyone advise as to where should this be located & also do we have a diagram on how it should be wired up?
Appreciate your kind help.
Thanks & Stay Safe
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Re: Hazard light location 250SL
« Reply #1 on: April 25, 2021, 06:01:14 »
Have you seen this?
https://www.sl113.org/wiki/Electrical/HazardWarningLights
It shows you the location of the switch and a template or coordinates where to drill the hole in the dash.
Be prepared to built your own sub-harness, but it is not too difficult once you found the necessary connectors:
https://www.sl113.org/forums/index.php?topic=30649.msg234630#msg234630
mauro12
  • Italy, Sicily, Messina
« Reply #2 on: November 06, 2022, 18:34:38 »
Hello guys , I’ve always wanted to ask this question . In my 250sl Italian version there is not the hazard switch light . Is this normal ? Why the car wasn’t equipped from the factory ? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
BobH
« Reply #3 on: November 06, 2022, 18:53:59 »
Hello Mauro, i believe US cars had to have hazard warning lights from the mid 60's.  In the UK it wasn't a requirement until the mid 80's, perhaps it was the same in Italy and other parts of Europe
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #4 on: November 06, 2022, 21:13:35 »
I have a 230SL which was built in the August/September, 1965, time frame but is registered as a 1966 model.  I have had it since new.  The emergency flasher switch is not mounted on the dash at all but is on the left side underneath the dash just in front of the hood release handle.  Very hard to see and you almost have to know about it to find it.  I guess the mounting changed as time passed.
BobH
« Reply #5 on: November 06, 2022, 22:12:37 »
Very strange location for a factory to fit it, from what i've seen it had moved to the dash by 67.  Possibly by 69 or 70 all cars had them from the factory, not just US cars
« Last Edit: November 06, 2022, 22:32:08 by BobH »
UK delivered RHD
Blue soft top
Blue leather
lpeterssen
  • USA, FL, Miami
« Reply #6 on: November 08, 2022, 11:27:21 »
Dear Mohan
You will need to build something like this. Ser attached picture. That is a hazard relay sub harness. In that way your main harness is not altered.
Best regards
Lp
  • USA, WI, Mequon
« Reply #7 on: November 08, 2022, 13:18:37 »
If it were my car, I would not put it in.  What for?  One less hole in the dash.
mauro12
« Reply #8 on: November 08, 2022, 21:54:52 »
I have seen some italian 230sl with the hazard light and some 280s too . I’m wondering if it’s a choice made by Mercedes’ or by the local regulations.
Mauro Pisani
Mohan58
« Reply #9 on: November 29, 2022, 13:35:06 »
Thanks so much.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
mauro12
« Reply #10 on: November 29, 2022, 13:42:26 »
Any 250sl Italian version with no hazard light ? I’m wondering if this item was removed from my car or was never equipped from the factory . I believe is very useful if you drive in modern traffic . If you get stuck in freeway or in a road with no lights.
My car is Italian version 250sl registered in Italy in July 1967
Mauro Pisani
Jordan
  • Canada, ON, Jordan
« Reply #11 on: November 29, 2022, 15:33:21 »
Mauro12, have you looked behind the fibre board under the dash on the drivers side (next to the hood release cable)?  You may need to remove the fibre board (not the dash itself) (couple of screws) as you won't see it by just looking up under the dash as it is behind the fibre board.  I have a German delivery Oct '66 230SL and I would not have known I had a hazard switch if I hadn't removed those panels under the dash.
Marcus
66 230SL  Euro 4 speed
mauro12
« Reply #12 on: November 29, 2022, 16:35:56 »
I have to dismantle the car to find this button ? Ahah . Why mercedes putted there ? Can you send some pictures ? Thank you
Mauro Pisani
« Reply #13 on: November 29, 2022, 19:40:57 »
That position does sound strange.  Maybe a previous owner moved it out of sight for some reason?
I'll have to look at my car, it was Italian delivery.
Jordan
« Reply #14 on: November 29, 2022, 19:46:00 »
Mine was/is located behind this panel.  Interior has since been changed so ignore the colours.
Marcus
mauro12
« Reply #15 on: November 29, 2022, 21:53:15 »
Wow ! Is like a treasure hunt . I will try to look if is hidden there . It’s been 20 years because we haven’t found yet since 2002 when we bought the car .
Mauro Pisani
« Reply #16 on: November 30, 2022, 00:24:15 »
I don't seem to have hazzard flashers in my Italian delivered 230SL, produced Oct 1966.
Jordan, maybe on your car a previous owner added the wiring and control, but didn't want to drill the metal dash??
« Last Edit: November 30, 2022, 00:34:59 by rwmastel »
Atazman
  • USA, Ca, Pleasanton
« Reply #17 on: November 30, 2022, 18:06:21 »
No hazard switch in my Italian 250 SL.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
gordon
  • United Kingdom, England, Burntwood
« Reply #18 on: December 16, 2022, 20:45:56 »
No hazard flashers on my UK 230 SL and with the advent of motorways with no hard shoulder to escape to other than refuges at quarter mile intervals I've fitted hazard flashers.
Obtained used 114 flasher from ebay and also the 6 pin female plug.  Soldered 1 wire ( 450 mm long) to each terminal and soldered  3 wires into the existing flasher plug and  3 into the multi plug from the steering column  all as follows
 Terminals 49a,. 15,. And 31 from the new plug (which fits into the new flasher unit) to the corresponding numbers on the original flasher plug. The old flasher is discarded.
The remaining 3 wires from the new plug are routed into the multiplug as follows L goes to black/white,. R goes to black/green and 30 goes to the red/white/blue in the multi plug.  I drilled the hole as per the Mercedes diagram,  it's a snug fit behind the dashboard and I ended up removing the chrome vent and moved the light switch aside to get it fitted. Works great.
My thanks to Jeremy Stevens the Merc club guru for the diagram and also fitting new guts into the switch I bought. I hope that this helps someone
gordon
« Reply #19 on: December 16, 2022, 21:10:21 »
Another picture
