Author Topic: search for parts, gaskets?  (Read 3649 times)
dirkbalter
  • USA, CA, Corona
« on: May 02, 2021, 20:49:14 »
All,
I am missing and I am on the search for item #172 on the brake booster assembly and item # 8 on the pedal assy. (see pics) My assumption is that these are just gaskets. Can someone confirm  this or correct me?
Thank you very much
« Last Edit: May 02, 2021, 20:58:29 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: search for parts, gaskets?
« Reply #1 on: May 02, 2021, 21:09:44 »
# 172 is a gasket, PN A 113 431 03 80, used as of chassis  044 006619. Not on part list before that chassis.
# 15 is a gasket too, PN A 113 431 03 80 (same), used as of chassis as above.
Not defined availability at MB.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: May 02, 2021, 21:22:29 »
Pawel,
Great, thank you.
I couldn't find the part #'s in my parts book or online.
(Gaskets, I can make myself.)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
GM
  • USA, CO, Boulder
« Reply #3 on: May 02, 2021, 21:54:46 »
Pawel is the part number genius of this forum!
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
dirkbalter
  • USA, CA, Corona
« Reply #4 on: May 02, 2021, 22:02:37 »
I know. He finds everything. ;)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #5 on: May 03, 2021, 07:49:05 »
Obviously overstated, but nice, thanks!
« Reply #6 on: May 06, 2021, 10:20:29 »
the gaskets are a black rubberized cloth.  very thin.  The closest thing I can think of is trucker's tarp material.  I would use a thin sheet of nitrile.  1/16" or so. Since the central hole already has a rubber seal sealing the rod I would imagine the function of the black rubber is either to prevent squeaks if there is any movement between the pedal/ booster assembly and the firewall or to add "Grip" to prevent movement.
dirkbalter
  • USA, CA, Corona
« Reply #7 on: May 06, 2021, 14:51:31 »
Thank you
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
