Author Topic: Aluminum trim moldings  (Read 2128 times)
Francis Abate
  • USA, CO, Steamboat Springs
    • First Ride Restorations
« on: May 05, 2021, 22:03:42 »
Does anyone know the grade of aluminum for the lower body and windshield moldings?  As I research anodizing shops I've been asked this question - I'm not sure if they all need to know this yet as I am still looking.  I believe these are the only anodized pieces on the 280SL but if not, I'd like to know that as well.
Francis E Abate
Owner - First Ride Restorations
http://www.firstriderestorations.com
Metal Fabrication, Welding, Trim & Upholstery
email: francis@firstriderestorations.com
dirkbalter
  • USA, CA, Corona
Re: Aluminum trim moldings
« Reply #1 on: May 05, 2021, 22:53:38 »
Not all grades of aluminum are anodize-able. That's likely why they are asking.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #2 on: May 06, 2021, 06:30:35 »
Sill trim is also anodized.
« Reply #3 on: May 06, 2021, 09:45:05 »
I am not sure you can re-anodize aluminum.
Francis Abate
« Reply #4 on: May 06, 2021, 21:05:47 »
Thanks for the tip on the sill pieces.  I believe the windshield surround may also anodized?
From what I am finding, you can strip, polish and re-anodize aluminum.  I am finding some sources out there but haven't settled on one yet.
Francis E Abate
mercakungen
  • Finland, Central Finland, Porvoo
« Reply #5 on: May 07, 2021, 11:15:50 »
You can re-anodize aluminium parts. The result will not be as bright when these cars were new. Back then bright anodized parts looked like almost chromed. If you buy a new original spare part from Mercedes you will get dull/satin finish.
Matti
-70 280SL
-57 Continental MK II
-70 Plymouth AAR Cuda
ex:
-61 220SEb Coupe "Kompressor"
-61 VW Karmann Ghia Coupe
-53 VW T1 "Zwitter"
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #6 on: May 07, 2021, 11:33:44 »
I got a set of lower body aluminum strips from the Polish bodywork parts supplier mentioned in the technical manual (Krzysztof Kuliński) 2 years ago. They are of excellent quality and fit very well.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
Kleine
  • USA, CA, Palo Alto
« Reply #7 on: May 07, 2021, 23:48:03 »
My experience trying to restore MB aluminum trim using bright dip anodizing is that it is an expensive waste of time.
The process may work on some aluminum but the Mercedes trim from W113 & W180 cars I tried to restore using
bright dip specialists came back with a 'sparkle' finish that looks funny in the sun. Polishing didn't improve it.
I asked folks at the MB Classic Center in Irvine who they used to anodize aluminum trim.  They told me their experience was the same so they
don't try to restore aluminum trim by anodizing it...they only replace it with new trim.
Joe
1966 230SL - 4 speed
doitwright
  • USA, IL, Willowbrook
« Reply #8 on: May 08, 2021, 05:35:57 »
That is the same conclusion I came up with. Preparing the trim for anodizing can take a lot of time and then you are at the mercy of who does the anodizing work. And most, the shops I called, do not do the brite-dip process. Without the brite dip, the aluminum will get dull again.
Frank Koronkiewicz
Willowbrook, Illinois
« Reply #9 on: May 08, 2021, 06:13:54 »
Three is a crowd.
Same experience here even after being assured that a "bright-dip" process will be used.
The process is described here:
https://kingoftrim.com/services/#services-2
