Author Topic: Interior rubber mats  (Read 2900 times)
pagoda113
  • United Kingdom, England, Surrey
« on: May 07, 2021, 18:10:27 »
New interior rubber mats arrived from my dealer today. They are exactly like my original ones in car. Also new holding studs for them.
Flim
  • United Kingdom, England, Flimwell, East Sussex
Re: Interior rubber mats
« Reply #1 on: May 08, 2021, 19:33:54 »
They look good!
Are the new mats grey or black? They look black in the photo outside the car and grey inside the car.
I also have these rubber mats in my 250SL but they are grey and am looking to replace them as they are original and in quite bad condition.
Charles
pagoda113
« Reply #2 on: May 08, 2021, 21:16:21 »
My apologies for the photo. They are grey just same as originals in my car. Just the way both pictures were taken and two different surroundings.
Mpfalkowski
  • USA, CT, Suffield
« Reply #3 on: May 09, 2021, 08:23:53 »
Good morning, very nice looking, could you share in US dollars what the cost was? Many thanks.
Matt Falkowski
1971 280 SL
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: May 09, 2021, 12:31:48 »
don't forget that the Classic Center has a 20% off-discount during the month of May. The link below shows the mats priced at $99.00 ea.
https://view.mbusa-email.com/?qs=72b6b4afed3fe1098fd09556ebcb1ac0f75c1ecd106c4e92bec5421d0fffc4fa745f71820c29986880f595a7b4d08c43fbbe1ac74c781304948039d49235130fb3b543170466396f#seven
Vander
  • USA, OH, Columbus
« Reply #5 on: May 09, 2021, 14:10:44 »
FYI These are floor coverings, not "mats" for early W113 cars. They are not correct for a 71 280SL as noted in your signature
pagoda113
« Reply #6 on: May 09, 2021, 17:11:32 »
I have more than 1 one pagoda lol. This is my 230sl with original floor coverings lol in.
« Last Edit: May 09, 2021, 17:22:27 by pagoda113 »
lowpad
  • USA, CT, New Preston
« Reply #7 on: May 09, 2021, 18:46:02 »
I am doing the same on my 230SL.  Couple of questions: what are putting below the mats?  AFAIK, they sat on some type of padding / insulation, but I can't find any specifics on it.  Also, did you just wind laying your new mats over the old ones to trim the driver's side correctly (ie, dimmer hole etc.)?  Would love it if you would show some final pictures when done for those of us that are installing them.   Many thanks!   Lowell
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
mauro12
  • Italy, Sicily, Messina
« Reply #8 on: May 09, 2021, 22:01:41 »
What is the mb part number to order this mats ? I will try to buy from my local dealer .
The 230 and 250sl early version are configured with carpet and this mats on the top , right ?
Mauro Pisani
250sl 1967 5speed zf manual
Desertpagoda
  • USA, AZ, Tucson
« Reply #9 on: May 09, 2021, 23:25:15 »
No, on the early cars, the tunnel, sills and the rear area are carpeted. These cover the front floor area, there was a jute-like partial pad under the mats and they were a sort of greyish color more than black
kb
« Reply #10 on: May 09, 2021, 23:51:56 »
Looks like they are only available in gray.  Some 230SLs came with a medium brownish tan rubberized floor covering that was a similar color to the medium brownish tan ribbed rubberized threshold covering.
mauro12
« Reply #11 on: May 10, 2021, 07:09:01 »
Is it possible to see some
Photos of the original configuration of the 230 and 250sl ?
Mauro Pisani
Flim
« Reply #12 on: May 10, 2021, 18:56:31 »
@pagoda113 do you still have the MB part numbers?
Although my 250sl is RHD... I guess the numbers would be different?
Charles
pagoda113
« Reply #13 on: May 10, 2021, 19:01:08 »
Sure here you go.
Flim
« Reply #14 on: May 10, 2021, 19:52:38 »
Thanks!
I like your 230Sl! Same colour as mine - Dark blue (332G?)
Is that a sump/oil pan cover/protector that I can see?
pagoda113
« Reply #15 on: May 10, 2021, 21:22:39 »
Thanks but it's actually 190G color code. Yes it has the 4 under  protective undershields option 481.
