Author Topic: Oval shims for the warm running device  (Read 2587 times)
col320ce
« on: May 08, 2021, 22:54:37 »
I decided to make these properly rather than bodge something. I bought 10cm square stainless steel 0.3mm and 0.1mm thick. I avoided aluminium as it's compressible when you tighten everything up.
The step metal drill bit was perfect for the job. I held it by hand to do the small holed then screwed it to the wood for the big hole.
If I got it off center I used a diamond bur to enlarge the hole on the correct side.
I used the dolly to make sure it was completely flat around the holes.
FYI I have a new thermostat that extends a lot so have only the thinnest round shim installed. I expect as it ages I'll remove an oval shim and put the same size back as a round shim.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
col320ce
Re: Oval shims for the warm running device
« Reply #1 on: May 08, 2021, 22:56:10 »
More pix
Col
1964 230SL
1965 250SE coupe
« Reply #2 on: May 08, 2021, 23:29:04 »
I had exactly the same idea to work with the staged drill while screwing the plate to a piece of wood. I an glad it works, need to make one or two.
