Author Topic: Ignition trim ring / bezel  (Read 1712 times)
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« on: May 17, 2021, 03:20:10 »
Before I admit defeat and fork out for a replacement part, has anyone found an ingenious way to keep an ignition trim ring (that has broken tabs) securely in place?
I have already bought a replacement rubber gasket which I thought would fix my issue. When trying to refit the trim ring one of the delicate tabs broke off... Leaving me with a lone remaining tab.
Any suggestions welcomed, tempted to break out the double-sided tape!
1971 280SL auto #571 over parchment
johnk
  • USA, OH, Avon
Re: Ignition trim ring / bezel
« Reply #1 on: May 17, 2021, 15:29:19 »
You could try adhesive caulk behind the trim ring. That is what I am going try if the ring I ordered two weeks ago doesn’t come through.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
kampala
  • USA, CA, Beach Cities
« Reply #2 on: May 17, 2021, 16:12:52 »
These trims rings were available for only a few $ a couple years ago from mbclassics.de I think about €12 maybe.
I bought a couple for both cars just in case I break them removing them for dash paint.
If he doesn’t show it on his site for your year car, just send a note. He is very responsive.
Buy other items you need to make shipping worthwhile.  No TVA/VAT (usually) when MBClassics sends to USA.
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #3 on: May 17, 2021, 19:47:57 »
I could not find them on parts list for some reason...
They are there available at SLS.
« Reply #4 on: May 17, 2021, 19:55:42 »
The dealer also can still get them.
About $35
« Reply #5 on: May 17, 2021, 19:57:26 »
I just could not find them on the parts lists. Tried 113, 111, 112, various groups...
« Reply #6 on: May 17, 2021, 20:04:26 »
Early style: up to 250sl vin 2979
1106890180
Late style:
1156890080
« Reply #7 on: May 17, 2021, 20:16:52 »
Found the late style, thank you! Group 68. Not on the picture, of course. Available, EUR 35-40, as you said.
