Author Topic: LED bulb in Tachometer  (Read 2897 times)
dakman29
  • USA, WA, Spokane
« on: May 18, 2021, 19:03:24 »
I have both my speedometer and tachometer out of the car after recalibration and cleanup.  I decided to replace the incandescent bulbs in both with amber LEDs from superbright.  They fit fine in the sockets and both went into the speedo without issue.  In the tachometer though I could only fit the LED in one of the two holes in the back of the instrument. The other hole has a noticeably smaller bore and the LED will not fit.  At this point I don't think I have an alternative other than putting the incandescent bulb back in that hole and the LED in the one where it fits.  Has anyone encountered a similar problem.  Thanks
GM
  • USA, CA, San Pedro
Re: LED bulb in Tachometer
« Reply #1 on: May 18, 2021, 21:19:02 »
You sand/grind down the diameter of the LED to make it fit
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Merc_Girl
« Reply #2 on: May 18, 2021, 22:44:49 »
Or make hole slightly bigger? I had to do this with the headlamp housing for my side light LED bulbs as hole was fractionally too small
230SL
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: May 19, 2021, 00:56:53 »
As Gary, I ground down the bulb.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Paul & Dolly
  • i Car
« Reply #4 on: May 19, 2021, 07:08:15 »
Or cut the narrow part of the tube off,  and fit the LED from the inside of the TACHO cover
Paul
« Last Edit: May 19, 2021, 07:19:42 by Paul & Dolly »
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
dakman29
  • USA, WA, Spokane
« Reply #5 on: May 19, 2021, 13:32:11 »
All very helpful solutions. Thanks!
mmizesko
  • USA, OH, New Albany
« Reply #6 on: May 25, 2021, 16:03:18 »
I ground mine down on a wheel
1970 280SL 291H Dark Olive
