Author Topic: Engine rebuild  (Read 2489 times)
GF280SL
  • United Kingdom, England, Saffron Walden
Engine rebuild
« on: May 23, 2021, 17:33:21 »
I am looking for a recommendation for an engine rebuild in the UK. Someone who is knowledgeable and thorough but does not charge the earth! Any suggestions? GF 280 SL :D
mauro12
  • Italy, Sicily, Messina
Re: Engine rebuild
« Reply #1 on: June 08, 2021, 08:15:31 »
Hi, sorry but since I’m not from uk I cannot give you an answer but I talked with my personal mechanic and he told me that an engine is an engine and for this reason a good mechanic should be able to rebuild every kind of engine . Do you need to rebuild the entire engine or only the head ? I’ve seen many pagodas solving their problems by only an head rebuild .
Mauro Pisani
250sl 1967 5speed zf manual
Re: Engine rebuild
« Reply #2 on: June 08, 2021, 12:23:45 »
I’ve had mine rebuilt twice. I won’t say who to avoid having this problem.
But ColinFerns (in Richmond) did it the 2nd time and it runs beautifully.
If you must be local, Hilton &Moss would work but cannot vouch for them, other than to say they project “pricey” and no idea if they do engines in house or send them out.
hansr433
  • Italy, Tuscany, Torrita di Siena
Re: Engine rebuild
« Reply #3 on: June 08, 2021, 19:15:38 »
Ciao Mauro, I really disagree with your mechanic.  True, any mechanic can probably put an engine together with the help of a manual, but to put together an engine that really sings requires tons of experience and "know-how".  See James' post - 2 mechanics - 2 different experiences with the same engine.
@James: would you know the hourly range one has to pay for good mechanical work in the UK?
Hans
1963 220SE Cabrio (Exterior: Navy MB 332, Top: Haarz Navy, Interior: 482P Sahara Beige)
1963 BMW R69S
Re: Engine rebuild
« Reply #4 on: June 09, 2021, 00:53:50 »
Other than being an overhead camshaft and a few quirks related to that our engines would be equally at home under the bonnet of a tractor.
mauro12
Re: Engine rebuild
« Reply #5 on: June 09, 2021, 20:10:22 »
What is the difference between an engine and our mercedes engine ?
A trained and experienced mechanic should be able to rebuild any kind of engine and not only Mercedes . If he doesn’t , is better that he changes his job I guess .
Mauro Pisani
