Hi everyone. I've found that it is sometimes a job to bring the bow below the rear window from the folded position to the lowered position when I am putting the top up. "Catch" refers to the two spring loaded pins attached to the lowering part of the frame that have to be pulled across the cam part of the frame - one on each side. Does that make sense? Each "catch" is a pin captured within a small cylinder and loaded by what appears to be a spring (not visible). The cylinder includes a screw on each side is adjustable with a screwdriver by turning to compress the spring further (harder to push the pin) or looser to reduce the compression of the spring (easier to push the pin).
What is the correct procedure for this adjustment?
Thanks in advance,
Harry
