In the parts list there are several part number changes without engine number description as a change date and there is one that provides the engine number at which the change was made:
Filler cap:
A 111 018 03 02
Replaced with
A 000 010 02 85 FILLER CAP (NO TEXT)
Note: As of engine: 980 10/50,20/60 009548 980 12/52,22/62 019394 981 10/50,20/60 000238 981 12/52,22/62 001536 983 10/50,20/60 003499 983 12/52,22/62 005621 984 10/50,20/60 000200 984 12/52,22/62 000092
Replaced with
A 000 010 12 85
Replaced with
A 000 010 14 85
The engine numbers are the same for all these 3 parts numbers into which the cap was changed (not sure what it means in reality).
The valve cover:
A 127 010 00 30 ROCKER COVER
Up to engine: 980 10/50,20/60 009547 980 12/52,22/62 019393 981 10/50,20/60 000237 981 12/52,22/62 001535 983 10/50,20/60 003498 983 12/52,22/62 005620 984 10/50,20/60 000199 984 12/52,22/62 000091
Replaced with
A 130 010 00 30
Note:
Up to engine: 980 10/50,20/60 026729 980 12/52,22/62 061162 984 10/50,20/60 000488 984 12/52,22/62 000237
Replaced with:
A 130 010 03 30
Note: As of engine: 980 10/50,20/60 026730 980 12/52,22/62 061163 984 10/50,20/60 000489 984 12/52,22/62 000238 - so this replacement did not apply to 983 engines.
Maybe the above gives some clue on change of cap and cover.
