Author Topic: manual shift linkage repair kit  (Read 1732 times)
Slowwindow805
« on: June 06, 2021, 17:45:44 »
Having a little trouble shifting up and down on our 230 and was told having this kit installed would help.  When shifting there is no grinding of gears just hard to find the gear and it just seems sloppy to me.  Has anyone had a shift linkage repair kit installed and did it really help?  Thanks for your help
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: manual shift linkage repair kit
« Reply #1 on: June 06, 2021, 17:53:53 »
Yes. I have replaced the bushings a couple of times over the years.
 You are running on borrowed time.  Makes a huge difference.
Here is some info
https://www.sl113.org/forums/index.php?topic=24733.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
JJ65SL
  • USA, MI, Holland
« Reply #2 on: July 01, 2021, 02:46:05 »
Just replaced all bushings (the 4 front ones were gone!) and rubber 2 weeks ago and it makes a huge difference!
John
1965 Euro 230 SL 4 Speed
‘84 purchase while stationed in Germany
124,000 original km/condition
717G/206
lowpad
  • USA, CT, New Preston
« Reply #3 on: July 01, 2021, 23:46:27 »
Ditto on borrowed time.  I waited to long and could barely shift. Easy, relatively low-cost repair. You will notice a huge difference!
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
yves
  • France, Poitou-Charentes
« Reply #4 on: July 02, 2021, 20:17:25 »
I have fitted  the kit a  few  days ago and had some issues with 2 bushes too thick  ( 1 mm each one !) i have grinded them carefully and pushed the shaft with a piece of wood from the the rear acces so the front fork could be fitted correctly
lreppond
  • USA, CA, San Leandro
« Reply #5 on: July 03, 2021, 02:45:35 »
I agree with the others about what a difference those bushings can make.  Shifting becomes much more precise.  After their installation, things will feel a tad bit stiff but the break in period doesn’t last long.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
