Author Topic: Oil hose to replace?  (Read 1954 times)
yves
  • France, Poitou-Charentes
« on: June 07, 2021, 17:32:44 »
Hi all, while i was checking the steering oil level , i had a look to the upper oil hose going to the oil radiator and i saw some very little cracks on it....
As i have replaced all the coolant hoses some months ago, i wonder if i have to replace that hose ?
I think it's a 20 years old hose .... and i don't know the fatigue life for theese hoses...  :-\
It seems "oily" when i touch it
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
Re: Oil hose to replace?
« Reply #1 on: June 07, 2021, 18:07:04 »
If it seems oily as you say then definitely change it. It’s an oil cooler hose, be careful when you unscrew it from the oil cooler so that you don’t damage the cooler itself since the fitting is weak and prone to failure.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
lreppond
  • USA, CA, San Leandro
« Reply #2 on: June 08, 2021, 02:09:50 »
I would check the lower oil coolant hose while you’re at it.   I just replaced both of mine and finding those hoses were difficult here stateside, especially the lower oil-engine hose.  I replaced using Cohline hoses without difficulty.  Got both on eBay!
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #3 on: June 08, 2021, 14:35:39 »
You have the original type replaceable hose fittings, don't throw them away!!!!
There is a post here for the correct hose to buy so you simply replace the hose and reuse the fittings. Sure, it is a bit of a hassle to change, but you will never be reliant on buying a premanufactured hose assembly.
If you don't want to reuse the fittings, let me know and I will pay the shipping for them.
