Please check out joining the
Emergency Contact List
for help during your travels!
General Discussion
Decoding Data Tag
Topic: Decoding Data Tag (Read 1662 times)
Eurosport Classic Motors
Full Member
Junior Level
USA, PA, Allentown
Decoding Data Tag
June 11, 2021, 16:01:23 »
1964 230SL #001930
Built January 1964
Can anyone decode each set of digits?
670 _____? 408 _____? 6 ______?
113042 10 (understood) 2 ______?
00042 ______? 00472 ______?
Rahul
Full Member
Senior
Bermuda, Devonshire, Paget
1971 280SL automatic #571, parchment
Re: Decoding Data Tag
June 11, 2021, 16:07:19 »
There is a comprehensive guide to the codes in the technical manual on this site
https://www.sl113.org/wiki/DataCard/Start
https://www.sl113.org/wiki/DataCard/BodyandPaintNumberPlate
Should find everything in there!
1971 280SL auto #571 over parchment
Full Member
Platinum
Germany, Nordrhein-Westfalen, Tecklenburg
Reply #2 on:
June 11, 2021, 16:55:07 »
Correct.
670: body color: light ivory
408 hardtop color: Havanna brown
6 - hardtop mounted (and softtop in softtop box/compartment)
113042 - means this is a 230 SL
10 - means lefthand drive (LHD) and manual gear box
2 - means European delivery - Germany
00042 - production number (within the workshift which actually 'fabricated' the car)
00472 - body number
Try getting the datacard (copy) from Mercedes-Benz, expensive but valuable for accurate restoration;
you'll find all those numbers there on the datacard again - and others.
datacardaficionadoandcollector
Full Member
Junior Level
USA, PA, Allentown
Reply #3 on:
June 11, 2021, 17:38:29 »
Outstanding info. Thank you very much 114015. This helps greatly!
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #4 on:
June 12, 2021, 00:16:50 »
If you wish to join as a Full Member for $30 usd and support the Group, you will be given full access to the Technical Manual where all this information is and as a bonus will be sent the bi-annual Pagoda World magazine and also access to Pagoda Notes. These will then provide you with a wealth of information to help you restore and maintain your Pagoda
Membership Administrator
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
General Discussion
Decoding Data Tag
