Author Topic: Mechanical Injection Pump seals supplier  (Read 4416 times)
lpeterssen
  • USA, FL, Miami
« on: June 13, 2021, 11:36:39 »
Dear Friends
I have been talking to my mechanic and we want to change some internal seals on the mechanical fuel injection pump on some of my cars to avoid fuel passing to the oil lubrication system.
There are many suppliers on internet which sell complete rebuilt kits for 100 to 250 usd, but we want to find the source or a place where to buy just some parts circled in red in the picture attached below.
Could someone give us a clue of who might be this supplier?
And also indicate which is the common name people give to the part we want.
Best regards
L.peterssen
Re: Mechanical Injection Pump seals supplier
« Reply #1 on: June 13, 2021, 13:21:38 »
Check valve seals?
Mercedes dealers, PN A 001 997 30 40, ca $8 per piece, 72hrs availability in my geography.
Just found this as well, Bosch PN 1 410 206 020.
As for the parts overall: for me it worked to use Bosch dealers/shops.
Whatever is available at Mercedes, I tend to buy from there as I have no shipping cost, can easily return the part and price is not that far from ebay or other sellers. Mercedes stock those parts, that might be used for FIP job listed in BBB, so not all the parts, but some are there, surprisingly. Some NLA, unfortunately.
« Last Edit: June 13, 2021, 14:48:48 by Pawel66 »
« Reply #2 on: June 14, 2021, 13:21:04 »
There may be two different versions of that seal?  I seem to recall a smaller one up until the ball check valves in mid 69 (?) and a larger one from then on.  If you go to mercedes they should be able to get some for you.
lpeterssen
  • USA, FL, Miami
« Reply #3 on: June 14, 2021, 13:25:13 »
Manu thanks to you all. My mechanic also mentioned that
« Reply #4 on: June 14, 2021, 16:28:27 »
I did not check the early or late version, good point from Shvegel. I can check if you want to.
lpeterssen
  • USA, FL, Miami
« Reply #5 on: June 14, 2021, 18:18:57 »
Will be nice for these cases
Engine M189 for W109-66
Engine M127 for W111-61
Engine M129 on w111-250Se 67
And late M130 69
Best regards and thanks Pawel in advance
L.peterssen
« Reply #6 on: June 14, 2021, 22:30:52 »
Sure, no problem, but this system does not work by years.
To be sure to give you the correct part number I need either the first 6 digits of the engine number or the first 6 digits of the VIN.
I did some guessing:
Engine M189 for W109-66: if this is M189.988 for W109.015, then PN is A 002 997 14 40, part unknown (means you have to ask about it), it is a different construction of the fitting, without a separate check valve; you would need to have the Bosch parts list (I have it for R25) and look for it at Bosch; in our manual I think there is some info regarding when these fittings changed
Engine M127 for W111-61: the only W111 I found with M127 was W111.014 with M127.982, but this engine had 2-section FIP and I do not see this seal there. If this is M127.982, then PN is A 002 997 17 40, $10, 72 hours availability. I do not know if this car had that engine...
Engine M129 on w111-250Se 67: if it is M129.980 for W111.023 or W111.021 - I need to know the VIN, there were changes identified by the VIN number
And late M130 69: for 130.983 it is what I wrote in the previous post. For others I would need 6 digits - there were changes by engine number for several M130 subtypes.
lpeterssen
  • USA, FL, Miami
« Reply #7 on: June 14, 2021, 22:58:15 »
Ok Pawel tomorrow will make a list of all the VIN number of my w111/109/112
Many many thanks
« Reply #8 on: June 15, 2021, 06:52:11 »
My pleasure!
lpeterssen
  • USA, FL, Miami
« Reply #9 on: June 15, 2021, 11:53:15 »
Dear Pawel
Here the list of cars looking for the FUEL INJECTION PUMP piston seal part number. There are cars with 2, 6 and 8 elements FIP listed
Many thanks in advance
Regards
Lp
mercedes
- [ ] W109 300 SEL 1966 engine M189 VIN10901512001379
- [ ] W109 300 SEL 1969 engine M100 VIN10901812002925
- [ ] W111 220SEb coupe 1961 engine M127, 2 elements FIP, VIN 11102112013240, engine 12796412000001
- [ ] W111 250SEb coupe 1967 engine M129.980.10.029098, VIN 11102110069115
- [ ] W112 300SEb coupe 1966, engine M189, should be same as first W109 VIN 11202112009382
- [ ] W113 280SL 1968 engine M130 VIN 11304412003550
« Reply #10 on: June 15, 2021, 21:11:20 »
Enclosed in pdf. Maybe helpful.
My experience is: you call the Bosch dealer, give FIP designation and explain what you need or give them part number and if it is available, they sell and send it to you.
I order from MB anyway what is there as it is faster, easier and I can easily return it.
In one of the case I could not find Bosch FIP designation. There used to be this electronic Bosch catalogue in the internet on their pages, where you punched in the car make and model and it showed you the entire equipment list. It is gone, but Bosch dealers have it (I just had to press them a bit), so I hoe this way you can identify the FIP, if you lost its plate.
Interesting: for W113 all subtypes have assigned engine type in the EPC. For the W109, 111 or 112 you gave me - none of them had engine type assigned, so I had to figure out engine type and look for the FIPs by engine number only. You may want to check if I used the proper engine numbers.
I am also enclosing FIP part list that I have at hand. It is just some of the FIPs (not only R25), but that is what I have.
lpeterssen
  • USA, FL, Miami
Where to buy in USA. Mechanical Injection Pump seals KIT
« Reply #11 on: October 10, 2021, 12:07:51 »
Dear friends
Anyone knows where to buy this mechanical fuel injection rebuilt kit in USA.  As you know I live in Venezuela, and purchases are easier when they are done in United States instead of Europe.
This is what I want to buy:
https://mercedes-classic-parts.com/product/afdichtset-brandstofinjectiepomp-bosch-f026t03029/
Listed for Eur 83 plus tax
I found this exact kit in vintage euro parts, for a much higher price than in the supplier in Denmark.
This what I found similar in vintage euro:
https://vintageeuroparts.com/index.php/chassis-number/w113/injection-pump-repair-kit-m127-981-m189-for-bosch-mechanical-fuel-injection-pump.html?___SID=U
Listed for usd 200.
Any guidance for solving this purchase will be much appreciated.
Best regards
L.peterssen
« Reply #12 on: October 10, 2021, 13:49:37 »
There were a lot of them on ebay - maybe also the US ebay?
lpeterssen
  • USA, FL, Miami
« Reply #13 on: October 10, 2021, 14:00:19 »
Dear Pawel
There are many on eBay usa, but all the adds are from vinntageeuroparts at usd 200 plus shipping instead of the price listed on the Denmark vendor for same thing at euro 83.
Best regards
L.peterssen
BobH
« Reply #14 on: October 10, 2021, 14:12:13 »
You could try these, they may be able to help?
https://injectionpumps.co.uk/
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lpeterssen
  • USA, FL, Miami
« Reply #15 on: October 10, 2021, 14:14:53 »
Excellent Bob
Will contact on Monday
Best regards
Lp
bracurrie
  • USA, TN, Nashville
  • The SL to have is a 113, but I don't have one.
« Reply #16 on: October 11, 2021, 16:35:35 »
This topic is bound to be interesting to all users of Mxxx engines that use Bosch MIP. Is there a list somewhere of the years, models, engines and injection pumps used?
Brad
1970 280 SE W108.018
M130.980 w/ US emissions
manual column shift
