Author Topic: gear lever bushes pb !  (Read 1597 times)
yves
  • France, Poitou-Charentes
« on: June 13, 2021, 14:02:57 »
 I am replacing the gear lever bushes plastic and rubber  with the SLS kit but it seems that i have some 2 white plastic bushes more than neccessary...!
Are they for another car ( 230 or 250 ?) in case ?
On the pic below  i have fitted the N° 1 but the bushes N° 2 are unemployed ?
Re: gear lever bushes pb !
« Reply #1 on: June 13, 2021, 14:11:49 »
Some models used bushings on both end of the two support rods. Those look like the ones that are at the end of the support rod, where it connects to the plate near the base of the shifter rod.
« Reply #2 on: June 13, 2021, 14:28:23 »
yves
« Reply #3 on: June 13, 2021, 18:57:42 »
Y're right...i am so stupid ..... ::) they are on the plate where the rods are fixed ....!
The plate was on the bench but my eyes were in the car  :o
Thank's both of you  ;)
yves
« Reply #4 on: June 14, 2021, 11:24:56 »
I have fitted now all the bushes but warning about the thickness of the two white big one which go at the front end of the shaft :
They are 1 mm too thick ( each one...!) and can't be fitted with the fork outside :
( kit from SLS i have called them for modification of the kit )
SEE above:
