Author Topic: Firewall Pad: Original vs. New  (Read 14661 times)
Tom230sl
Re: Firewall Pad: Original vs. New
« Reply #25 on: May 02, 2005, 09:29:15 »
As for the pad material, I would assume if someone had that diamond pattern material as New Old Stock in a roll, it would be rather valuable ; )
« Reply #26 on: May 02, 2005, 12:25:56 »
Originally posted by Douglas
Vince is also correct about the radio suppression piece at the hood latch, however, I believe they were only seen on US-spec Pagodas.
My Italian Pagoda has the radio suppression spring on the hood latch.  Also, on the front axle grease caps there is a tab that contacts a point protruding from the axle.  This is for radio noise suppression as well.
Quite a tangential journey from firewall pads to brass springy things!
norton
« Reply #27 on: May 02, 2005, 13:14:49 »
Take a couple of steps, and there you are :D
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Reply #28 on: May 03, 2005, 05:32:43 »
Jonny B,
Probably at the livery change over number 2979--2980
« Reply #29 on: May 03, 2005, 14:22:15 »
Bob, you are likely correct. All kinds of things shifted with the 250SL at that VIN break point.
Tom230sl
« Reply #30 on: May 03, 2005, 16:59:08 »
Yeah, things kinda went down hill after the 230SL
« Reply #31 on: May 03, 2005, 18:11:35 »
Tom,
Oh boy, is that the start of a whole 'nuther can of worms!
