Author Topic: removing fuel injectors question  (Read 5500 times)
yves
  • France, Poitou-Charentes
« on: June 17, 2021, 13:46:40 »
I am trying to test and clean my fuel injectors and can't unscrew the first accessible nut  ( 1)  without bending the fuel line and unscrew the second nut (2) on the engine !
Is there a special tool  for doing that ?
There is not enough room for two wrench . One to block one nut and the other to unscrew... :(
« Last Edit: June 17, 2021, 13:55:10 by yves »
scoot
  • USA, CA, Altadena
Re: removing fuel injectors question
« Reply #1 on: June 17, 2021, 13:54:26 »
I don't remember the size (14 mm?) but the tool looks like this.
Scott Allen
'67 250 SL (early)
Altadena, California
yves
« Reply #2 on: June 17, 2021, 13:56:38 »
Whaou Allen that's a very explosive answer ....!
Thank's i'll order that"wrench"
And the size is 17 for the first nut and 19 for the other   ;)
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: June 17, 2021, 14:00:44 »
I use the same tool as Scoot and a crows foot for bottom nut to hold in place. I might have even cut down a sacrificial wrench instead of a crows foot.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Vander
  • USA, OH, Columbus
« Reply #4 on: June 17, 2021, 14:05:14 »
The injection line wrenches are made by Hazet, they make them in both 3/8" drive and 1/2" drive.
3/8" drive tool number is Hazet 4550
1/2" drive tool number is Hazet 2745-1
Once you get the injection line separated from the injector, you can put a deep well socket on the injector to remove.
yves
« Reply #5 on: June 17, 2021, 15:33:55 »
I have tried with a sacrifcial wrench  19 mm at the bottom nut and a 17 mm at the upper one without succes even with a strong effort....! and i don't want to break the line. So it seems that the "scoot" tool must be the right one but i can't find it on the net....
mrfatboy
    • Mrfatboy
« Reply #6 on: June 17, 2021, 15:39:50 »
When you used the 19mm on the bottom did you brace/lodge against the head so it will not twist?  If you don’t have that set it will never work whatever you use on the injector/top nut.
Signal Red
4 Speed
yves
« Reply #7 on: June 17, 2021, 16:04:47 »
Well I don’t know the words brace /lodge but I think you must say that the bottom wrench is very strongly blocked against a solid stuff… it’s the case ! 😬but I wait to have the right crowfoot wrench
« Reply #8 on: June 17, 2021, 16:09:49 »
You can also try a penetrant on the area where the fuel line goes through the nut. That can corrode very easily and cause binding. I would recommend using a VERY light coat of antiseize at this juncture when assembling. Makes it a breeze next time you need to take it apart. Also you torque the injector (20 Ft. lbs???) and the fuel line nut at around (18ft. lbs). Confirm these values first! The point being that the nut is torqued down with a lower value than the injector. In theory this will allow the nut to break free first before the injector.
yves
« Reply #9 on: June 17, 2021, 16:30:27 »
That makes sens Wallace Thank’s
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #10 on: June 17, 2021, 17:22:04 »
Hello Yves,
You can find it on Amazon:
KS Tools 152.1401 - Clé pour alimentation d'injecteur - En matière Robuste et Résistante
Visiter la boutique KS TOOLS
  Prix :   37,69 €
Not cheap, but at least it’s available…
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
« Reply #11 on: June 17, 2021, 20:54:37 »
I use two of those shown by scoot with two extensions and two ratchets. I had to, however, grind the 19mm (bottom nut) so that it fits all 6 injectors locations.
mrfatboy
    • Mrfatboy
« Reply #12 on: June 17, 2021, 21:44:28 »
This is what I use.
Signal Red
4 Speed
« Reply #13 on: June 17, 2021, 22:02:44 »
Yes, fitting this 19mm is the biggest issue... probably this is the best way.
yves
« Reply #14 on: June 18, 2021, 11:10:24 »
I have customised the 19 mm wrench and wait for the 17 mm .....
 And i sprayed some WD40 .... ::)
sandcrab59
  • USA, MA, Lunenburg
« Reply #15 on: June 19, 2021, 16:32:33 »
I have used these same wrenches on my diesel engines for many years. Hazet is the best.
Of course I purchased these wrenches many years ago, so I guess they cost more now.
these wrenches make it very simple.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #16 on: June 19, 2021, 18:52:48 »
I've found that removing the valve cover gave me more room to work. Those line fittings can get really tight sometimes.
« Reply #17 on: June 19, 2021, 23:12:57 »
As Benz Dr stated, Removing the valve cover makes the job far less frustrating and can be done with common tools.
yves
« Reply #18 on: June 22, 2021, 18:26:24 »
I used the tools as Fatboy with succes ...
I have tested the spray of each injector and found only 2 with a "spray" the other 4 have a simple jet .
So i put them in a fuel cleaner solution back flush position .... for a day and see the level of the cleaner.
I can put them also in a ultrasonic tank and wonder what liquid i'll pour in ?
The same cleaner should be correct
« Last Edit: June 22, 2021, 20:24:55 by yves »
« Reply #19 on: June 23, 2021, 15:16:16 »
I have successfully cleaned injectors using an ultrasonic cleaner along with Chemdip carburetor cleaner (the one gallon soaking solution). The key is to carefully open the nozzle pintle and insert a small piece of plastic such as the end of a zip-tie to keep it open. Because the injector seats are made of steel, if they are corroded, no amount of cleaning will fix them.
yves
« Reply #20 on: June 23, 2021, 22:28:35 »
I  have tested the injectors after cleaning and 1 injector remains with a simple jet....i am glad with that unhoped result  ;)
So i am on the ultrasonic process for the 6th and will see the result .
I have opened the tip  with a needle ..... for the 6  inj .
Looking very close to the bottom of the injector where the tip is , i see a very little hole beside the tip but wonder what it is used for...?
yves
« Reply #21 on: June 24, 2021, 14:42:05 »
Well No progress with the ultrasonic bath for 2 hours.... The defective injector remain defective...
So i send all the injectors to a injector specialist even if 5 of them make a nice " tchip tchip" when i put them under pressure at 220 PSI without any dripping before .
At least i think i should have only one injector to replace  ::)
Btw i was thinking about refitting them on the engine after refurbishing : what is the torque for the injector  and for the pipe nut ?
« Reply #22 on: June 24, 2021, 16:27:04 »
Lots of posts on this topic (injectors cleaning) with a very low success rate, usually ending: I spent two days on it and then bought a set of new ones...
My sucsess rate was finally ca30% and I bought new ones. :)
dirkbalter
  • USA, CA, Corona
« Reply #23 on: June 24, 2021, 16:57:42 »
Torque for the injectors is 35Nm (manual). I don't think there are torque settings for the pipe nuts in the manual.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
WRe
« Reply #24 on: June 24, 2021, 17:37:16 »
here are the torques for a 280SL.
...WRe
