If your injectors are as corroded as they seem to be, its also likely that there is some of the same scale deposits down inside at the pintle end as well. I would recommend bench checking them all as I did with this test rig I bought and adapted.
It allowed me to visually check the spray pattern and cracking pressure on each one of them.
Larry in CA
