Author Topic: 67 230sl  (Read 2482 times)
Bconley759
67 230sl
« on: June 21, 2021, 21:15:21 »
Where can I find the Big Blue Book? I've seen a couple manuals not really impressed.
Re: 67 230sl
« Reply #1 on: June 21, 2021, 21:24:07 »
The usual place to start is right here. Someone may have one.
Next up is eBay, the come up on a reasonable basis. Not usually cheap, but out there.
Have you had a chance to look through one? It might not provide what you are looking for, as it presupposes a fair amount of Mercedes background knowledge.
Don't get me wrong, it is a good source, depends a bit on where you are coming in from, mechanics wise.
Have you looked at the Haynes manual? That is a pretty good tool, and are easily available on eBay, Amazon has one at a very reasonable price:
https://www.amazon.com/Mercedes-1968-1972-6-Cylinder-Roadster-Automotive/dp/0856963461/ref=sr_1_15?dchild=1&keywords=haynes+manual+mercedes&qid=1624310596&sr=8-15
« Last Edit: June 22, 2021, 15:43:31 by Jonny B »
MikeSimon
  • USA, OH, North Royalton
Re: 67 230sl
« Reply #2 on: June 21, 2021, 22:12:59 »
I have to side with JohnnyB. If you don't like any of the manuals out there, you will not like the BBB. You have to consider that the BBB was made for the Mercedes mechanic. Not for the Shade Tree wrencher. You need a lot of specific Mercedes knowledge to use the BBB effectively. While it has some good reference data, it is a terrible instruction guide to specific repairs.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
steveq
Re: 67 230sl
« Reply #3 on: July 06, 2021, 17:14:03 »
I have a Haynes manual which does cover the 230,250 & 280. It is good but not great for a 230SL. I think it is more focused towards the 280SL
For example, it only talks about disc brakes on the rear and my 1965 230SL has rear drum brakes. Your '67 car might have disks. There were many, many upgrades over the years even on the 230SL so no manual will be perfect.
I also have the Autopress Mercedes Benz 250 1965-68 which covers the 250SL. That is good but is not focused on the 230SL (of course).
I recently bought an Autobooks Owners Workshop Manual for the Mercedes Benz 230 1963-68. That covers the 230, 230 S and 230SL and is very good (and covers the rear drum brakes well).
I am in the middle of a significant brake overhaul job on my 230SL, hence the brake obsession !!
I also recently bought a DVD copy of the BBB. It is a very large PDF file. Difficult to have beside you when you are working on the car but has good search facilities and was a lot cheaper than buying the hardcopy BBB.
Be careful which BBB you are buying as they were updated every few years and you want one that covers your car but not the 250SL or 280SL.
The BBB is very technical and quite difficult to follow for amateurs like me. However it has every piece of detail you could ever possibly want (and more). Also, it reads like it was directly translated from German and so is a somewhat unclear.
merrill
Re: 67 230sl
« Reply #4 on: July 06, 2021, 20:45:02 »
you can also check here for hard copies
https://books4cars.com/listings.php?findmake=Mercedes&model=280SL%20&year=3000&type=%
you may still be able to find them on CD rom from mercedes.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
