Author Topic: What is the ‘rivet’ used on ‘floating’ bar on soft top  (Read 2121 times)
Merc_Girl
Hi folks
So, back to re-assembling the soft top frame, after giving it all a good clean
There is a metal bar that sits between the windscreen and the first ‘fixed’ bar, which is only attached to the strapping.
To me it looked like a rivet, almost like you have as a ‘popper’, but the other side was flat. I’ve been told it is a rivet nut, but looking at these they have a ‘hole’, going all the way through, which mine didn’t have
Is anyone able to advise please?
Many thanks
Katie
230SL
Re: What is the ‘rivet’ used on ‘floating’ bar on soft top
« Reply #1 on: June 22, 2021, 13:53:39 »
It sounds like you are referring to a closed end pop rivet.  They must have wanted a more finished look from the bottom.
https://www.albanycountyfasteners.com/item/Countersunk-Pop-Rivets-3-16-304-Stainless-Steel
Merc_Girl
« Reply #2 on: June 22, 2021, 21:59:34 »
That looks like it, thank you!
230SL
