Author Topic: Rubber plug part number?  (Read 4316 times)
« on: April 29, 2005, 15:13:59 »
Does anyone know the correct part number for the rubber plug for the heater assemblie on the firewall of our SLs . I would appreciate it.
thank you
Re: Rubber plug part number?
« Reply #1 on: April 29, 2005, 17:50:33 »
Are you typing about the feed and return lines for the heater core. My 250 parts book lists these as
Feed line - 113 997 01 81
Return line - 113 997 00 81
The listing is Table 34, Group 83
From the picture in the book they appear to be the firewall grommets for the inlet and outlet lines at the firewall.
« Reply #2 on: April 29, 2005, 19:43:39 »
If you are referring to the inspection plug to the core valve, it should be 113 987 24 44.
« Reply #3 on: April 30, 2005, 05:02:31 »
Hi Bob,
One of the 1st items I replaced on my car.  PN 113 987 24 44.  Paid $6.00 at the dealer.  It was hard to get on, need to sort of rotate it while inserting and pushing down.
Memphis, TN.
1997 E320
« Reply #4 on: April 30, 2005, 08:19:32 »
Can you guys still get the 113 987 24 44 in the US.
When I tried to order them here, I was supplied 110 987 0044, which looks like a cap that would go on the end of a poster tube.
Also its the wrong diameter and would fall into the hole if not careful.
« Reply #5 on: April 30, 2005, 09:21:29 »
Hey Naj, the plug I got from Star Quality (old one)is like you describe. It has a lip. In my case, we were dealing with a firewall that originally had no access hole. Somewhere along the way, my mechanic decided to add one [:0] -- so I actually had to make the opening larger to have it fit. So much for originality!
