Author Topic: Faulty Ignition switch?  (Read 3269 times)
Harry
  • USA, TN, Knoxville
« on: June 22, 2021, 19:16:53 »
Gorgeous weather, top down - and my 230SL will start right up but shuts off as soon as you release the key from the start position.  If you hold a little clockwise pressure on the key after it starts, it will continue to run.  My guess is that this is a problem with the ignition switch.  Thoughts?  Similar experience?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
dirkbalter
  • USA, CA, Corona
Re: Faulty Ignition switch?
« Reply #1 on: June 22, 2021, 19:30:32 »
Harry
Harry,
Sounds like it. I have had it on mine and replaced my neighbors as well. The same symptoms, occasionally shutting down and key wiggle required to make contact.... . The crimp tends to get lose after 50 years. They are repairable but a pain the get out.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Harry
« Reply #2 on: June 22, 2021, 19:45:17 »
Thanks dirkbalter.  What is the crimp that you're referring to?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
dirkbalter
  • USA, CA, Corona
« Reply #3 on: June 22, 2021, 20:10:34 »
Harry,
The cap is "crimped" to the body in 3 place on the OD. I am attaching a very nice write up from the German colleagues. Its in the first few pictures. I believe an English version is floating around somewhere too. A repro switch is also available from SLS, Buds...
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
