Author Topic: What to do, what to do!!  (Read 3058 times)
Merc_Girl
« on: June 23, 2021, 08:00:32 »
Sorry folks, you will be fed up of me by now!!
However, I’m in a conundrum.
Almost finished re-trimming the front ‘blade’ of the soft top. I am rather pleased with myself, on my third attempt I thought I was there.
BUT, shock, horror, it looks as though the frame brackets that fit onto the ‘blade’, sit under MB tex, not on top of!!!
The question is, Would it be considered sacrilege to mount the brackets on top?
230SL
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: What to do, what to do!!
« Reply #1 on: June 23, 2021, 08:42:54 »
It might just be because it’s 1:37am or I’m reading this in the dark on an iPhone 🤣 but I’m not sure what you are asking. I can’t make out the red text in the photo.
I attached a photo of my top before I trimmed the fabric if that helps. Or can you restate the question?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Merc_Girl
« Reply #2 on: June 23, 2021, 09:00:38 »
Sorry, nicked the photo from another part of the forum, so please ignore very small print in red!
So, I have cover the front ‘blade’ in MB Tex, second photo.
However, looking at other pictures, an example I ‘stole’ from another part of the forum (1st picture), it is evident that the two ‘arms’ that join the frame to the front blade, sit under the MB Tex
I’m therefore how sacrilegious it would be to mount the  the two ‘arms’ on top of the MB Tex, thus avoiding having to unglue the work I have already done and hoping the material will still reach where it needs too. Another point maybe worth mentioning is that I spent ages polishing the ‘arms’ thinking they were visible!,
Ta
Katie
230SL
mrfatboy
    • Mrfatboy
« Reply #3 on: June 23, 2021, 09:25:14 »
For me it would be sacrilege😜.  I would always know and I would see it every time😖
Signal Red
4 Speed
« Reply #4 on: June 23, 2021, 11:11:36 »
No one will no but you.  If you are OK with it fine.  If it is going to bother you do it over.  I discovered a trick last year that helps with MB-tex in tight areas.
https://www.sl113.org/forums/index.php?topic=32708.msg238031#msg238031
mrfatboy
    • Mrfatboy
« Reply #5 on: June 23, 2021, 11:40:20 »
Nobody”s gonna know 🤣🤣🤣🤣🤣🤣
https://youtu.be/UODIbKWGADo
Signal Red
4 Speed
« Reply #6 on: June 23, 2021, 15:19:36 »
I will........... :)
Jordan
  • Canada, ON, Jordan
« Reply #7 on: June 23, 2021, 16:30:38 »
Sorry Katie, but we all know now.  ;)
Marcus
66 230SL  Euro 4 speed
Merc_Girl
« Reply #8 on: June 23, 2021, 21:52:06 »
Come up with cunning g plan, going to cover it up afterwards!! Also means garage can do adjustments if needed 😁
Ya, so everyone will know my dirty little secret now 🤣🤣🤣
230SL
Merc_Girl
« Reply #9 on: June 23, 2021, 21:54:08 »
Thanks for link, will save for next time ….. 😁
230SL
Merc_Girl
« Reply #10 on: June 23, 2021, 21:55:26 »
230SL
