I have installed a 123 distributor on my '63 230Sl. I need to know if I should still use, connect, the vacuum line/tube from the intake CSV to the port on the 123 distributor. The distributor I replaced is the Bosch 051. I know I don't need the other components of the 051, condenser etc. I also installed the RED coil.
Regards, Paul Sorgen, Early 1963 230Sl, 2021 E Class 4 Matic
