Author Topic: Rear axle camber  (Read 2690 times)
2rsan
Rear axle camber
« on: July 05, 2021, 20:48:37 »
Hi, after restoration the rear axle has a positive camber of 3 deg. All springs are the same. Does not look right.
What can be wrong?
Re: Rear axle camber
« Reply #1 on: July 05, 2021, 22:39:51 »
Have you driven the car at all? When the Pagoda is up in air with the wheels hanging, they will give a positive camber as they sag. When the car is down the wheels take time to re-adjust. That is the usual item. After a short drive they usually come back to the normal position.
Not a bad idea to double check the bolts, shocks etc to be sure all are okay.
2rsan
« Reply #2 on: July 06, 2021, 17:24:05 »
Yes the car was been driven and I am aware of the problem you decribe  ;) ;)
I see now in the part manual that the upper spring rubber grommet comes in different hights. Will check what is on the car. Any other suggestions?
« Reply #3 on: July 06, 2021, 17:30:28 »
Things that can affect rear camber:
Spring cushions.
Spring platforms.
Centre spring (and its cushion)
Rear axle centre mounting.
Rear axle pivot bush being incorrectly installed.
Carbon fiber panels.  ;)
