Author Topic: 67 230sl  (Read 1823 times)
Bconley759
67 230sl
« on: July 09, 2021, 15:43:27 »
Doing a total resto, I have the rear axle on the bench and can visible see the need for seals on the vertical axle support. Got a couple books but they don't give a clear enough detail on take down. The same goes for the torque arm removal. Then finding just seals is another problem. Anyone have some input for me?
dirkbalter
  • USA, CA, Corona
Re: 67 230sl
« Reply #1 on: July 09, 2021, 17:14:04 »
I believe the BBB (full version) explains the procedures on the rear end quiet well. All the parts you need are still available. If money is no issue, MB will be the best source.  Otherwise, the German vendors (SLS, Niemoeller...) tend to be less expensive than the local ones (Buds, Authentic classics...) assuming you buy enough parts to offset the shipping cost.
Sometimes parts are still available from known discount retailers such as Pelican, Autohaus, Rock Auto......
There is also a lot written on the forum here on rear ends...
I think you need to be more specific with your question.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Bconley759
Re: 67 230sl
« Reply #2 on: July 10, 2021, 11:25:52 »
I went ahead and took things apart and found what I needed at Buds Benz and KK, thanks for the info, its been quite the adventure still have a long way to go.
